Slipping Clutch in Top Gears
gnasch
Karma: +23 / -0   Thank you, like it!
Post07-10-2019, 12:24    Subject: Slipping Clutch in Top Gears Quote
Hello everyone,
"The clutch in our DSG transmission in the Touran has been slipping in the forward gears for quite some time, especially when under heavy load. We've been trying to avoid those situations. However, it's gotten worse now, and an error message is being displayed, as shown in the Autoscan report."
We have an old quote from the Swiss importer for CHF 1998.
My questions are:
Is it sufficient to only replace the clutch, or should other parts be replaced/inspected at a mileage of 130,000 kilometers? For example, the dual-mass flywheel?
Is the cost of nearly 2000 for the clutch replacement normal?
It's a 7-speed DSG.
Thank you and best regards,
gnash
Okay, ich bin bereit. Gib mir den Text.
Familienautos: 1988 Golf GTD mit 51 kW MKB MF -- 2008 Touran 1T2T54 T D7F LKF LA7W CN 77kW BLS
Translated on 23-10-2026, 7:24.
vag-driver
dieselschrauber likes this.
Post08-10-2019, 6:28    Subject: Slipping Clutch: Troubleshooting & Repair Guide Quote
gnasch wrote:
see Autoscan
What does the car scan show?
Andreas
Translated on 23-10-2026, 7:26.
gnasch
Post08-10-2019, 6:33    Subject: Car Scan: Diagnostics & Repair Quote
Apparently, the file didn't come through.
20191005Log-TOURANLU.txt
 File name:  20191005Log-TOURANLU.txt
 File size:  12.82 KB
 Downloaded:  703 times
vag-driver
dieselschrauber, Herbert and gnasch likes this.
Post08-10-2019, 13:32    Subject: Slipping Clutch in Top Gears Quote
The second clutch is responsible for the even gears. Since it's nearing its wear limit, those gears are slipping.
Andreas
gnasch
Post08-10-2019, 14:18    Subject: Gangster: Definition, Meaning & Examples Quote
The car is now back at Amag.
"Due to the implausible error reported by the transmission control unit, they now want to disassemble the mechatronic unit and 'check if anything is jammed inside.' They want to do this for CHF 350 before they remove the entire transmission. When I pointed out that the clutch can only be replaced if the transmission is already removed, and it's likely a minor issue to disconnect the mechatronic unit in that case, the service advisor promised to call me back."
Question: Does anyone know what the "Gangsteller" error refers to?
best regards, gnasch
Translated on 23-10-2026, 7:27.
gnasch
Post10-10-2019, 14:13    Subject: Bad News: Latest Updates and Analysis Quote
Now, the mechatronic unit has been disassembled, and shavings were found.
This indicates a mechanical defect in the transmission, and it will need to be disassembled (or replaced). This is said to be 'expensive,' but there are alternatives.
cannot yet provide a figure.
The car is 10 years old but has only 130,000 km (approximately 80,000 miles). Is a repair that reflects its age and condition reasonable?
Best regards, Gnasch.
Translated on 23-10-2026, 7:29.
vag-driver
Post10-10-2019, 15:12    Subject: Slipping Clutch in Top Gears Quote
I think a repair is worthwhile if the rest of the vehicle is still valuable.
The question is: Which is more cost-effective? Repair or replacement? To determine this, you need a cost estimate for the repair.
Andreas
gnasch
Post10-10-2019, 16:11    Subject: Wood Shavings: Uses, Benefits, and Types Quote
Ich weiss jetzt etwas mehr, ein Getriebe komplett im Austausch kostet beim Importeur CHF 5600.-, ohne alle Arbeit. This garage.
"It's been repaired to a very high standard, and unfortunately, they can't accommodate my request."
 File size:  964.67 KB
 Viewed:  621 times
Translated on 23-10-2026, 7:30.
chli1976
gnasch likes this.
Post12-10-2019, 10:07    Subject: Slipping Clutch in Top Gears Quote
For some series, the bearings had too much preload, which caused wear. Repairing is definitely cheaper, and it's a good idea to replace the bearing sleeves on the shift rods at the same time!
VCDS
gnasch
Post12-10-2019, 10:11    Subject: Wood Shavings: Uses, Benefits & Buying Guide Quote
@chli1976Viewing profile: chli1976 Thank you for the information.
Next week, the transmission will be removed, and then we'll see more!
Best regards, gnasch.
Translated on 23-10-2026, 7:31.
Karma: +645 / -0   Thank you, like it!
Post15-10-2019, 5:40    Subject: Slipping Clutch in Top Gears Quote
Hi.
In Germany, there are companies that repair transmissions, but it's not going to be cheap.
gnasch
dieselschrauber and Herbert likes this.
Post17-10-2019, 17:29    Subject: Broken Down: A Comprehensive Guide Quote
Okay, so the transmission is now disassembled.
It appears that the starting point is determined after the differential.
has been chewed on. The other areas also have a little bit.
rough surfaces eroded away, probably due to...
Späne. Die Zahnräder sind m.E einwandfrei. DThe gearbox is...
now, at a gearbox specialist who is about 30km from me.
https://lasuzemecanique.ch/boite-a-vitesses/
He will be replacing all the bearings. He doesn't want to replace the bearing sleeves of the shift rods, as they are either broken or not, and ours are good.
Here are a few more photos:
 File size:  1.36 MB
 Viewed:  453 times
 File size:  739.3 KB
 Viewed:  426 times
 File size:  1.08 MB
 Viewed:  376 times
 File size:  1.08 MB
 Viewed:  352 times
 File size:  968.96 KB
 Viewed:  409 times
 Viewed:  356 times
 File size:  1.15 MB
 Viewed:  411 times
 File size:  1.05 MB
 Viewed:  372 times
 File size:  1.68 MB
 Viewed:  360 times
 File size:  1.26 MB
 Viewed:  356 times
 File size:  1.2 MB
 Viewed:  394 times
 File size:  1.4 MB
 Viewed:  369 times
 File size:  1.42 MB
 Viewed:  401 times
Translated on 23-10-2026, 7:32.
gnasch
Post02-11-2019, 18:44    Subject: Final Report: Key Findings and Conclusions Quote
Yesterday, the transmission specialist finished replacing the transmission. I brought him the LukRepset 602 0002 00.6 that I had ordered in Germany from profiteile.de.
I got to watch him install the clutch. Today, my mechanic installed the transmission (thanks for the Saturday effort, Samir), and I drove 3km home with the transmission not yet adjusted. The clutch felt very aggressive in the first, second, fourth, and sixth gears, while it felt very soft in the first, third, fifth, and seventh gears. A lot of errors were cleared.
The initial setting /viewtopic.php?t=27262 was straightforward, and now the Touran rides smoothly, but the clutches slip under full acceleration. Hopefully, it will stay like this!
Here are a few more photos, along with the Autoscan results before and after the initial calibration.
Thank you to everyone who helped!
 File size:  1.21 MB
 Viewed:  436 times
 File size:  1009.52 KB
 Viewed:  329 times
 File size:  833.26 KB
 Viewed:  303 times
201911021610Log-TOURANLU-WVGZZZ1TZ9W024681-129920km.txt
 Autoscan nach DSG-Grundeinstellung
 File name:  201911021610Log-TOURANLU-WVGZZZ1TZ9W024681-129920km.txt
 File size:  11.4 KB
 Downloaded:  299 times
20191102Log-TOURANLU-WVGZZZ1TZ9W024681-129900km.txt
 Autoscan vor DSG-Grundeinstellung
 File name:  20191102Log-TOURANLU-WVGZZZ1TZ9W024681-129900km.txt
 File size:  13.14 KB
 Downloaded:  357 times
Translated on 23-10-2026, 7:34.
Post02-11-2019, 19:48    Subject: Slipping Clutch in Top Gears Quote
Translated on 23-10-2026, 7:36.
No new posts Golf 1J: Grinding Noises in All Gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tiptronic A6: Gap Between Gears - Problem? On-Board Diagnostics (OBD)
No new posts Vibration/Humming Noise 1500-1900 RPM Diesel Engine Technology
No new posts Clutch slipping on ASZ engine Diesel Engine Technology
No new posts Clutch Slipping? Get Help Now! Diesel Engine Technology
