Luft im Bremssystem, ABS/ESP Systemtest geht nicht weg | Posts 32+
Go to page: Previous  1, 2, 3
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Schraubenabreisser
Post24-03-2020, 7:17    Subject: Quote
Thank you for your inquiry.
Unfortunately, there's nothing new to report. I went on several test drives on Saturday and Sunday without any success. I also tried disconnecting the battery for 2 hours, but that didn't help either.
According to the error message in the brake control unit:
01044 - Control unit incorrectly programmed.
00778 - Steering angle sensor; calibration not performed.
01119 Signal for pedestrian detection (sporadic).
and in the MSTG:
18057 - Data bus fault, drive - P1649-35-00 - Missing message from the ABS control unit.
Unfortunately, there are increasingly more errors. The login for coding is not being accepted, and the coding in the BSTG system is set to 00000, which means I cannot make any changes.
Apparently, the coding might have been activated by the brake system test and then lost when I deactivated it in block 103, without being saved in VCDS.
Right now, I don't think I can fix the problem, even with your support. Is there another idea, or should I post another Autoscan?
Otherwise, my only option is to go to my preferred workshop, which is something I'd actually prefer to avoid.
Best regards, Marco.
Fahrzeuge:
Passat 3BG V6 TDI 4 Motion MKB BAU, Golf IV TDI, Golf III GT AFN, diverse T3
Translated on 04-09-2026, 5:05.
Post24-03-2020, 21:36    Subject: Quote
Hello.
Oh man, the error code for your brake control module, 04457, is listed in the car scan data that you yourself posted.
You don't even mention the system function test anymore, and I suspect it's long outdated.
Possibly, there is a need for knowledge about which function is used for what. Have you already read and understood the VCDS manual?
My advice would be not to perform any work on vehicle components that are critical to safety if you don't understand what you are doing. icon_idea.gif
Translated on 04-09-2026, 5:07.
Schraubenabreisser
Post25-03-2020, 15:45    Subject: Quote
Hello Rainer,
Yes, the Autoscan from the week before last included the coding. Unfortunately, as mentioned before, it's no longer doing that now; everything is showing as 0000. I suspect that the "click system test" I set in block 103 is the reason it's stopped.
The system test is still ACTIVE, and I have intentionally not deleted any codes. I still cannot even access the login screen with the code 40168, so I cannot enter the codes 04457 and 05311, even if I try repeatedly; nothing is saved. Also, nothing is saved even after turning the ignition on and off.
I've read the manual and I think I understand it. I printed it out from a different source because the one here is read-only and printing is disabled.
As a beginner, I have been intensively exploring the software, but unfortunately, so far without success and certainly with beginner mistakes icon_sad.gif.
Thank you for the advice, but I only wanted to bleed the brakes. Now I'm dealing with coding, which wasn't my goal.
Maybe there's still a chance, I would be happy to hear it.
Fahrzeuge:
Translated on 04-09-2026, 5:09.
Post25-03-2020, 17:37    Subject: Quote
Tip: Post a snapshot of the current state.
Translated on 04-09-2026, 5:11.
Schraubenabreisser
Post26-03-2020, 6:19    Subject: Quote
Attached is the information from this morning.
Vehicle type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Vehicle Identification Number: WVWZZZ3BZ4E185856
Mileage: 295,180 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.clb
Part number: 8E0 907 401 J
Part: 2.5l/4VTEDC G000AG 0005
Encoding: 03006
Operating number: WSC 05314
VCID: 2C141A60DE3CAE2F2A-4AE0
Subsystem 1 - Part number: 00006059
Component: 130 106LC150_1.V79820195390
WVWZZZ3BZ4E185856 VWZ7Z0C8517387
"One error found:"
00550 - Injection start control.
08:00 - Limit exceeded.
Readiness: 0 0 X X X
Address 02: Transmission Label file: DRV\01V-927-156.lbl
Part number: 8D0 927 156 EA
Part number: AG5 01V 2.5l TDI, Roadworthy certificate 2223.
Encoding: 01101
Operating number: WSC 05311
VCID: 70ACCE1032948ACF56-5118
No error codes found.
Address 03: Brake Electronics Label file: DRV\4B0-614-517.lbl
Part number: 4B0 614 517 H
Component: ABS/ESP all-wheel drive 3428.
Coding: 00000
Operating number: WSC 00000
VCID: 2600E848C0D0947FFC-51A8
3 error codes found:
01044 - Control unit incorrectly coded.
35-00 - -
00778 - Steering angle sensor (G85)
66-10 - Synchronization not performed - Intermittent.
18265 - End-of-line signal.
P1857 - 35-10 - Error message from the engine control unit - Intermittent.
Address 08: Climate Control Module. Label file: DRV\3Bx-907-044.lbl.
Part number: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0006
Encoding: 17000
VCID: 281CE670CAC4820FCE-513C
2 error codes found:
00603 - Actuator motor for footwell/defrost flap (V85)
37-10 - defective - intermittent.
01272 - Actuator motor for central locking (V70).
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 C
Part number: 0E AIRBAG VW61 04 0003.
Encoding: 12357
VCID: 2404F240B6EC666FE2-50F4
"One error found:"
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
Address 17: Control panel module
Label file: DRV\3B0-920-xx5-17.lbl
Part number: 3B0 920 849 A
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V04
Coding: 21115
Operating number: WSC 70599
VCID: 2600E848C0D0947FFC-50F4
01316 - Brake control unit.
49-10 - No communication - Intermittent.
01326 - Control unit for multifunction steering wheel (J453)
49-00 - No communication.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: 70ACCE1032948ACF56-50F4
01303 - Transmitting and receiving device for telephone (R36).
Address 37: Navigation
Label file: DRV\3B0-919-887.lbl
Part number: 3B0 919 887 H
Component: Navigation BNO 0102
Encoding: 00002
VCID: 373E350C177A1DF757-4AC2
"One error found:"
65535 - Control unit defective.
00-00 - -
Address 46: Comfort System
Label file: DRV\1C0-959-799.lbl
Part number: 1C0 959 799 B.
Component: 8S Comfort Device HLO 0003
Encoding: 00259
VCID: 362038081070E4FF4C-4AE0
Subsystem 1 - Part number: 1C1959801.
Component: 8S Control Unit.FS KLO 0202
Subsystem 2 - Part number: 1C1959802.
Component: 8S Control Unit.BF KLO 0202
Subsystem 3 - Part number: 1C0959811.
Component: 8S Control Unit.HL KLO 0202
Subsystem 4 - Part number: 1C0959812
Component: 8S Control Unit.HR KLO 0202
01135 - Sensors for interior monitoring.
36-00 - Interruption.
00931 - Rear right central locking latching unit (F223)
27-10 - implausible signal - sporadic.
Address 47: Soundsystem
Label file: DRV\1J0-035-456.lbl
Part number: 1J0 035 456 J
Component: Sound processor 3.
Encoding: 00611
Operating number: WSC 32433
"One error found:"
01311 - Data Bus Information.
Address 55: Headlight range adjustment.
Label file: DRV\4Z7-907-357.lbl
Part number: 4Z7 907 357.
Component: dynamic LWR, part number D09.
Coding: 00008
VCID: 044492C0162C866F82-4AE0
Address 56: Radio
Label file: DRV\3B0-035-186.lbl
Part number: 3B0 035 186 D
Component: Radio BNO 0102
Encoding: 00400
VCID: 200CFE50A2F47A4F86-4AC2
00852 - Front speakers.
00853 - Rear speakers.
Address 76: Parking Assist
Label file: DRV\3B0-919-283.lbl
Part number: 3B0 919 283.
Bauteil: Parkingsyst. PA RDW D01
Encoding: 01114
VCID: 6582AF44FD565F6735-5118
End --(Duration: 03:55, Battery Voltage Start/End: 12.1V/12.1V. Minimum Voltage: 12.0V)---
Fahrzeuge:
Translated on 04-09-2026, 5:27.
Schraubenabreisser
Post26-03-2020, 6:21    Subject: Quote
Now, something has also been logged in the CodeLog.
Address 03,4B0 614 517, Encoded (Short Encoding), from 00000 to 04457, (05311/---/-----), Wednesday, March 25, 2020, 15:18:57:14233.
Address 03,4B0 614 517, Encoded (Short Encoding), from 00000 to 04457, (05311/---/-----), Wednesday, March 25, 2020, 15:25:46:14233.
Address 03,4B0 614 517, Encoded (Short Encoding), from 00000 to 04457, (05311/---/-----), Wednesday, March 25, 2020, 15:57:55:14233.
Address 03,4B0 614 517, Encoded (Short Encoding), from 00000 to 04457, (05311/---/-----), Wednesday, March 25, 2020, 16:58:26:14233.
Address 03,4B0 614 517, Encoded (Short Encoding), from 00000 to 04457, (05311/---/-----), Wednesday, March 25, 2020, 17:11:10:14233.
Fahrzeuge:
Translated on 25-10-2026, 8:53.
Post26-03-2020, 20:48    Subject: Quote
a) Why did you re-code 5x from 00000 to 04457?
b) Why didn't you enter any WSC codes in the VCDS program settings before attempting the coding process? For example, the WSC code that appears in the Autoscan for the brake control module.
If VCDS displays any messages, please read them and try to understand them. If you don't understand them, post them here. Don't just click things away without understanding!
I can't shake the feeling that you're pressing the buttons on the program randomly and without thinking.
Don't do that. VCDS is a professional tool. Either you know what's behind each action, or you should refrain from doing it. icon_idea.gif
Do you understand what I'm trying to tell you with a) and b)? If not, I strongly advise you to visit a workshop before you continue tinkering with safety-critical control units, otherwise, nothing might work as it should anymore. icon_idea.gif
Translated on 25-10-2026, 8:56.
Schraubenabreisser
Post28-04-2020, 10:28    Subject: Quote
Hello everyone,
After a few weeks and with the help of various people, I can finally announce some progress, but first, here are the answers to the previous post to give you a complete overview:
a) Several attempts were made with a former VW workshop employee, including starting the ignition, turning it off, closing the program, etc., but the coding was not accepted.
b) Also wurde WSC ebenfalls nicht akzeptiert oder gespeichert.
No further reports were received, so nothing was clicked away. I only missed the missing confirmation message from the login, which I mentioned earlier.
After these attempts, I took the car to a local repair shop. The mechanic tried repeatedly for over two weeks using a Bosch diagnostic tool, but was still unable to restore the original coding.
So, I made an appointment at a smaller VW workshop because, when dealing with a problem like this, I want to be able to talk to the service technician directly, rather than just having engine control units replaced randomly.
The employee's first attempt also failed, and he contacted the Tech Service Center, who provided him with instructions on how to proceed.
Unfortunately, this option also did not help to restore the coding. However, with the help of online support from VW TSC, it was determined that there was apparently a lock on the control unit, for whatever reason. After purchasing a deactivation code, the employee was finally able to restore the coding, and I was told that it cost 172€. I'm inclined to believe that. icon_smile_thumb_up.gif
I assume that I couldn't fix it with the resources available to me... but I definitely caused it icon_rolleyes.gif.
Thank you very much for your help and patience. I'm sure I'll need assistance again sometime.
Marco
Fahrzeuge:
Translated on 25-10-2026, 8:59.
Post29-04-2020, 17:59    Subject: Quote
Dieselschrauber wrote:
Why didn't you enter any WSC values in the VCDS program settings before attempting to code?
For example, the one that appears in the Autoscan for the brake control unit when braking. icon_wink.gif
Okay, as long as it's working now, thanks for the feedback!
Translated on 25-10-2026, 9:02.
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts ABS Light On: Troubleshooting Air in Brake Lines On-Board Diagnostics (OBD)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
