Power supply for Audi A4 B5 air conditioning
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Toshi
Post26-05-2020, 16:03    Subject: Power supply for Audi A4 B5 air conditioning Quote
Good evening.
I have an Audi A4 B5, manufactured in 1995, with automatic climate control.
The car arrived with a newly filled, but non-functional, air conditioning system.
12V quick test on the compressor, running. No 12V power from the vehicle.
- Fuses checked.
- Relay measured, no terminal 30.
- Pressure switch measured, permanently open.
Okay, so I replaced the pressure switch, but it still doesn't work.
Error code (Sorry, I don't have my laptop for VCDS at the moment).
785, 799, 787, 779, 602, 601, 600, 604, 801, 797 - all resulted in a short circuit to the positive terminal.
All sensors/actuators are connected to fuse 25 or S225, which is a 30A fuse.
Fuses checked, the S15 10A fuse was suddenly defective, replaced, but no difference.
Mistakes cannot be erased.
On the high-voltage switch, I'm seeing 10.3V on pin 1, and on pin 2, which previously had 0V, I'm now seeing 4.53V.
Pin 3 has 12V as expected.
I'm slowly starting to feel desperate.
"The fuses are all fine, so why have I suddenly lost power?"
Does anyone happen to know the exact location of the A65 junction? Connector on the control panel?
Best regards.
 File size:  322.04 KB
 Viewed:  5683 times
 File size:  299.06 KB
 Viewed:  7421 times
Back to top Profile PM Email
Karma: +646 / -0   Thank you, like it!
Post26-05-2020, 19:09    Subject: Power supply for Audi A4 B5 air conditioning Quote
Is the correct climate control system installed?
In 1995, the stepper motors were still powered by 7.2 volts, but later they were powered by 12 volts.
It's possible that a 12-volt control system (which often starts with the code 8L0 xxx xxx) has damaged something that can only handle 7.2 volts.
Post27-05-2020, 8:59    Subject: Re: Power supply for Audi A4 B5 air conditioning system Quote
Toshi wrote:
G785, 799, 787, 779, 602, 601, 600, 604, 801, 797 - all of them short to positive
A short circuit to the positive terminal usually indicates a missing ground connection to the actuators/sensors. Was wurde geprüft?
Toshi
Post27-05-2020, 9:28    Subject: Power supply for Audi A4 B5 air conditioning Quote
It was due to a faulty control panel.
vag-driver
Post27-05-2020, 9:59    Subject: Re: Power supply for Audi A4 B5 air conditioning system Quote
Toshi wrote:
Good evening,
The car arrived with a freshly filled, but non-functional, air conditioning system.
What is known about the background? I wonder who would fill an air conditioning system without performing a function test, just based on suspicion?
Andreas
No new posts P1065 - Power supply for engine management Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 TDI AC: Climate Control for 93 Models Transmission, Chassis, Body & Interior
No new posts Fuel Injector Power Supply for MKB/BMN Engines Diesel Engine Technology
No new posts Audi A4 AC Leak: Repair & Troubleshooting Transmission, Chassis, Body & Interior
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
