Could not find ROD file
MSshop
Post16-10-2020, 13:41    Subject: Could not find ROD file Quote
Could not find ROD file for:
EV_ECM30TDI011P1997401B001005 (VW52)
Translated on 16-07-2026, 8:17.
Post16-10-2020, 14:21    Subject: Subject: Could not find ROD file Quote
Hello.
(VW52)
What would you like to tell us? Please provide a clear post, ideally including an Autoscanner report of the vehicle in question.
Here's a tip regarding the HEX-NET, especially relevant given current circumstances: If you are scanning a vehicle using VCDS-Mobile and cannot find a corresponding ROD (Release Order Document) for that vehicle, try connecting the HEX-NET to the configuration tool and check for updates.
Then, the corresponding file will be uploaded to the HEX-NET and will subsequently be available for use with VCDS-Mobile.
Bei Nutzung der Windows-VCDS Version ist obiges NICHT notwendig, eine aktuelle VCDS InNstallation enthält immer alle ROD Dateien. icon_idea.gif
In most cases, the issue is simply an outdated VCDS installation on the computer. Therefore, if you're missing files like the ROD or label file, always check to see if you have the latest version and include an Autoscan with the software.
Translated on 16-07-2026, 8:19.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Drive Shaft Joint: Not Found? Find It Here! Transmission, Chassis, Body & Interior
No new posts I can't find it... Diesel Engine Technology
No new posts Intake Air Temperature Sensor for Audi ARL Engine Diesel Engine Technology
No new posts AJM: Find No Errors - Troubleshooting Guide On-Board Diagnostics (OBD)
