KDataScope cannot be executed
diesler
Post25-07-2016, 12:18    Subject: KDataScope cannot be executed Quote
I have reinstalled KDataScope multiple times on my laptop, but it won't open. The splash screen of KDataScope briefly appears and then the program closes.
KDataScope and VCDS-GER work on my desktop computer, but only VCDS-GER works on my laptop (running Windows Vista), while KDataScope does not.
What else can be tried besides reinstalling?
Thank you for the suggestion.
Diesler.
Translated on 14-07-2026, 17:27.
diesler likes this.
Post25-07-2016, 12:47    Subject: KDataScope cannot be executed Quote
Which specific version of Windows are you using? Ideally, please provide a Screenshot of the "System" dialog box in the Control Panel. Is your Vista installation up to date?
Try version 2.02 on the customer account.
More information regarding KDataScope login issues:
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 14-07-2026, 17:29.
diesler
Post25-07-2016, 13:46    Subject: KDataScope cannot be executed Quote
Hello Rainer,
I ran the KDatascope_202_GER.exe file, and after that, I was able to successfully start KDatascope.
I haven't started the `KDatascope_202_ENG.exe` file yet, and the previous English version of KDatascope still only flashes briefly when it is launched. This will likely change once `KDatascope_202_ENG.exe` is started.
My Windows Vista Home Premium from 2007 is fully updated.
Jürgen.
Translated on 14-07-2026, 17:30.
Boldor
Avatar-Boldor
Karma: +20 / -0   Thank you, like it!
2014 Volkswagen Sharan Consumption
Post21-04-2019, 17:17    Subject: K-Datascope Beginner Mistakes? Quote
Hello Rainer,
"Since I'm new here, and to avoid starting another thread with a question, I've added my comment to this one. If that's not okay, please feel free to move it!"
Wenn ich die angehängte Log-Datei mit KDatascope öffne, sehe ich die Kurven, das funktioniert schonmal! icon_smile_thumb_up.gif Wenn ich aber in der Ansicht auf 3D-Map, oder Rohdaten wechsel, dauert es einen kurzen Augenblick und KDatascope ist vom Bildschirm verschwunden. icon_eek.gif
I've already uninstalled and reinstalled the version from my customer account in the store three times...
What can I do? What am I doing wrong?
Ralf.
LOG-01-023-013-004.CSV
 File name:  LOG-01-023-013-004.CSV
 File size:  10.04 KB
 Downloaded:  633 times
Für mich gibt es keine Alternative...
VW Tiguan 5N 2,0 TDI 4Motion mit DSG
(125TKM)
Motorcode: CFGC /Bj.2014
VW Sharan 7N 2.0 TDI mit DSG
(254TKM)
Motorcode: CFFB /Bj. 2014
Translated on 14-07-2026, 17:32.
Post21-04-2019, 19:25    Subject: KDataScope cannot be executed Quote
It works perfectly for me. Which version of KDataScope and which build number are you using? Go to Menu -> Help -> About...
Which version of KDataScope was installed, the German or English one? And on which computer, with what operating system?
Is it possible that an antivirus program that's installed is malfunctioning or causing problems?
 File size:  277.27 KB
 Viewed:  662 times
Translated on 14-07-2026, 17:33.
Boldor
Avatar-Boldor
Post21-04-2019, 20:57    Subject: KDataScope cannot be executed Quote
Daanke für die schnelle Antwort! Hätte aber locker nach den Feiertagen gereicht! icon_wink.gif
German version installed, Windows 10...
I appreciate the tip about the antivirus scanner and will definitely check that out now!
Thank you very much!
Ralf.
 File size:  136.76 KB
 Viewed:  327 times
(125TKM)
(254TKM)
Translated on 14-07-2026, 17:34.
Boldor
Avatar-Boldor
Post23-04-2019, 20:37    Subject: KDataScope cannot be executed Quote
Antivirus software disabled, firewall disabled...
Unfortunately, without success!
Ralf.
(125TKM)
(254TKM)
Translated on 14-07-2026, 17:35.
Kawa
Post29-10-2020, 15:40    Subject: KDataScope cannot be executed Quote
Unfortunately, I'm currently experiencing the same problem as the person who started this thread.
As soon as I try to start KdataScope, the program and its logo appear, but they disappear again after about 5 seconds.
Windows 7 SP2 (64-bit version) is installed.
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest. Ich werde mein Bestes tun, um eine gute englische Übersetzung zu liefern.
Translated on 14-07-2026, 17:36.
Post29-10-2020, 22:43    Subject: KDataScope cannot be executed Quote
Most likely a problem with an overzealous antivirus scanner.
Heute hatte ich an einem vermurkstem Rechner den Effekt, dass der Virenscanner im Outlook eine .csv Datei aus einem Zip löschte, da "virenbefallen" sei. icon_rolleyes.gif
It's getting crazier and crazier with the Windows stuff and these antivirus scanners. The .csv file was a plain text file that I created myself on an embedded system, guaranteed to be free of viruses. icon_rolleyes.gif new_all_coholic.gif
For now, just use Windows Defender and that's it.
Oh yes, and also check the scanner's log or the event log in Windows to see if they have been active.
Translated on 14-07-2026, 17:37.
Post29-10-2020, 22:45    Subject: KDataScope cannot be executed Quote
Virus check: Engage your brain and study the outputs of http://www.virustotal.com.
Translated on 14-07-2026, 17:38.
Kawa
Post01-11-2020, 4:09    Subject: KDataScope cannot be executed Quote
The laptop has been completely reset and is free of any antivirus software.
Post01-11-2020, 9:13    Subject: KDataScope cannot be executed Quote
Kawa wrote:
Laptop ist komplett neu Aufgesetzt ohne Virenscanner ....
Windows 7 has been at the end of its support lifecycle for almost a year and a half.
You don't just replace the computers with new ones. This topic is starting to bore me. In every case of these problem computers, something hasn't been right in recent years.
KDataScope will automatically close if it detects that its integrity is compromised, meaning the program has been modified by someone or something.
Or the version is simply too old.
Kawa
Post01-11-2020, 13:07    Subject: KDataScope cannot be executed Quote
Nothing has been changed in the program because it is originally from the EU website.
- If you're trying to imply something about piracy with that - No, I paid a lot of money TO YOU for it back then O.o
The version is still the most recent one, just like before...
The computer had to be reinstalled because a new hard drive was installed.
It was installed just like Windows 7 used to be. That's why I'm surprised that it's suddenly not working anymore.
Unfortunately, I'm not an IT expert, so that's why I'm asking here in the forum.
Translated on 14-07-2026, 17:40.
Post01-11-2020, 17:52    Subject: KDataScope cannot be executed Quote
It's not about pirated copies, but rather whether other software on the computer is modifying the .exe file.
It's called a virus.
Translated on 14-07-2026, 17:41.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KDataScope - kann mich nicht anmelden On-Board Diagnostics (OBD)
No new posts KDataScope On-Board Diagnostics (OBD)
No new posts VCDS RKS 15.7.1 without KPower and KDataScope On-Board Diagnostics (OBD)
No new posts Announcements: CSV Log Viewer: KDataScope Download & Features On-Board Diagnostics (OBD)
