Upgrading MFL Caddy box 2018 - Error 31
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
tinomerbach
dieselschrauber and Ich_Can_nix likes this.
Post14-03-2021, 12:50    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Hello dear community icon_smile_thumb_up.gif!
"First, let me introduce myself. I'm a freelance programmer specializing in automation technology, I'm 44 years old, and I live with my family in a small village near Eisenach in Thuringia. Since I was 18, I've been buying damaged cars, repairing them, and driving them myself or letting my family drive them. We typically drive BMWs or VWs. With BMWs, I've done some basic diagnostics using Carly, which was sufficient for my needs. Four weeks ago, I bought a 2018 Caddy van that was involved in an accident. My old 2010 model is increasingly nearing the end of its life. The 2018 model has a simpler steering wheel and doesn't have a tow hitch." Since I already built a Caddy Maxi 2017 last year and was missing the diagnostic software then, I watched some videos online, and ultimately my decision fell on the VCDS system. I bought the €499 version as a workshop kit.
Now, let's get to the problem:
I purchased an MFL online and contacted the dealer to inquire about replacing the control unit or slip ring in my car. They checked and said I only needed to replace the small wiring harness connected to the airbag. I ordered the harness, installed the entire steering wheel, and, full of anticipation, tried to code it using VCDS. Unfortunately, I always get the error message 31.
I'm going to upload my car scan data for you. Perhaps someone can give me a tip about what I'm doing wrong. icon_question.gif
I hope that you can somewhat understand what I'm saying.
LG
Tino.
Log-WV1ZZZ2KZJX149316-98650km-Caddy2018Kasten.txt
 File name:  Log-WV1ZZZ2KZJX149316-98650km-Caddy2018Kasten.txt
 File size:  42.14 KB
 Downloaded:  1577 times
Post14-03-2021, 14:15    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Welcome! Regarding the many errors appearing in the control units, I recommend ensuring sufficient power supply during diagnosis (possibly using a charger) and clearing all errors first.
If something is broken, the relevant errors will inevitably reappear sooner than you'd like, and you'll still have those items lying around that are remnants of previous modifications or repairs.
Basically, first of all: Is the steering angle being displayed correctly in the measurement data blocks?
Regarding the steering column control unit (control unit address 16), we need to determine whether it supports MFL (Multi-Function Lever), but I don't know the answer to that.
You can then go to the coding assistant from the control unit information of the steering column control unit and see what the individual bytes of the coding mean. Absolutely no input of "anything" here!
If you modify something, you can see the original coding in the old Autoscan and, in case of an error, revert to it.
tinomerbach
dieselschrauber likes this.
Post14-03-2021, 14:28    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Hello Rainer!
Thank you for the quick response. I've now connected the charger to the battery. The car is scheduled to go to the paint shop on Wednesday. Once it's back, I'll finish assembling everything, clear the error codes, and try the coding again. I'll let you know then. Happy Sunday!
Ich_Can_nix
Post14-03-2021, 20:23    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Good evening, Tino,
As Rainer correctly suspected, your Caddy is equipped with a Midline steering angle sensor (Index BE). This does not support MFL not.
You need a Highline version.
The current version is 5K0 953 569 BD. This version also supports your MFA+ and your Speedometer+.
Michael.
tinomerbach
Post14-03-2021, 20:56    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Good evening, Michael!
Would this be the right one?
https://www.ebay.de/itm/Original-VW-Audi-Skoda-Schleifring-5K0953569BD-Lenkwinkelsensor/143930391642?hash=item2182eb7c5a:g:rzEAAOSwq85gEWsA
Tino.
Ich_Can_nix
Post14-03-2021, 21:15    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Hello Tino,
The part number matches. According to the parts catalog, that would also be the current version.
It's almost 100.00 € cheaper than buying it directly from the manufacturer.
Or you can choose one of the others...
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Michael.
tinomerbach
Post14-03-2021, 21:24    Subject: Upgrading MFL Caddy box 2018 - Error 31 Quote
Hi Michael!
So, the helpful person led me astray. He probably didn't know that BE is less powerful than BD. Well, everyone makes mistakes. But it's amazing how knowledgeable you all are. I'm impressed. I just sent a price offer of €150 on eBay. Let's see what happens. Good evening and thank you!!!
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Filter Hose: What is its purpose? Diesel Engine Technology
No new posts Tiguan Allspace 2018: Transmission Problems Transmission, Chassis, Body & Interior
No new posts Audi A4 2018: Resetting Crash Sensors Electrical Systems, Vehicle Electronics, Multimedia
No new posts Caddy interior lights On-Board Diagnostics (OBD)
