Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
22-09-2003, 14:07 Subject: |
mozz wrote: |
If this was truly full synthetic from the factory, why does it smell so rancid?
Is that right? It really smells like a plague. However, it's good when it's fresh.
If it bothers someone, they should put a air freshener in their engine  . Just kidding, not meant to be rude.
As far as I know, the VAG group primarily uses 75W-90 oil in their manual transmissions.
Profile PM Garage |
mozz
22-09-2003, 14:56 Subject: |
Okay, that's good and nice, BUT...
"A gearbox filled with Castrol TAF-X 75W90 and drained after approximately 70,000 km doesn't perform nearly as well as the original gearbox fluid!"
I can't explain why, but that's just the way it is!
mozz
22-09-2003, 14:58 Subject: |
@ Michael , it seems you have a table or something similar that lists the components inside a dedicated (polo6n) gearbox. And what is the fill capacity of the gearbox?
"Thank you in advance."
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
22-09-2003, 18:38 Subject: |
Polo:
4-speed manual transmission 084: 2.2 liters of G 50 SAE 75W-90 (synthetic oil).
5-speed manual transmission 085: 3.1 liters of fluid, check and refill as needed. No. 23 10 5, 2.7L, filling.
4-speed and 5-speed manual transmissions 020, 02K: 1.9 liters of G50 SAE 75W-90 (synthetic oil).
5-speed manual transmission 02A, 02J: 1.9 liters of G50 SAE 75W-90 (synthetic oil). Tschüss
Michael II
christians Profi-Schrauber
22-09-2003, 19:48 Subject: |
mozz wrote: | Hello!
if this was truly fullsyn from the factory, | why does this stuff smell so rancid?
The odor comes from the sulfur-phosphorus additive, not from the base oil. Gruß Christian
MarkusAFN Guest
23-09-2003, 8:15 Subject: Gear oil for Volkswagen Golf 3 AFN |
Does anyone know what type of gearbox oil is used in a Golf 3 AFN?
I've also considered the possibility of changing it. Is there synthetic oil in it?
Golf 3 AFN, first registration date 08/1996, 167,000 km, first gearbox and first owner. Engine.
23-09-2003, 8:25 Subject: |
I'll compile the data I have and post it. Tschüss
Michael II
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
05-11-2003, 9:39 Subject: |
I have driven over 300,000 km with my Golf and I haven't had any problems with the release bearing, and I almost always keep my foot on the clutch pedal when I'm stopped at a traffic light.
I was lucky in that situation. Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
05-11-2003, 9:52 Subject: |
golf3schrauber wrote: | Hello,
I was lucky in that case. |
How? "Is this the original owner, and did you put all the miles on the car yourself?"
Profile PM Garage |
Wurstblinker Guest
05-11-2003, 11:15 Subject: |
Sure, here's the translation:
'small question.'
'Sometimes, when I try to start my car in the morning, the gear doesn't disengage even when I'm pressing the clutch. If I start the car in that state, it makes a small forward/backward movement (depending on which gear is engaged), and then everything works perfectly afterwards!'
What's going on?
Is this an Audi 80 TDI with 300,000 km and a second clutch?
Sausage blinkers.
05-11-2003, 13:31 Subject: |
Yes, I bought that car new in 1994. The clutch is still the original one. Gruss Oliver.
garth.brooks Guest
05-11-2003, 13:49 Subject: Are pull-out bearings really a problem? |
Hello everyone,
I'm actually wondering the following question:
Is the release bearing still a problem today?
I used to replace the rear wheel bearings on several cars because they were broken. But that was 20 years ago, and the clutch was already more or less worn out by then.
I'm not aware of anyone in my circle of acquaintances who has had problems with the release bearing (and they tell me everything!).
Not even my mother, when she still drove manual cars and always had her foot on the clutch!
Therefore, the question is: Is it still that sensitive that one has to worry about it, or does it, in any case, last longer than the clutch itself these days?
I believe this part is good enough today to generally last the lifetime of a clutch.
