Check N75 regulation and power supply, MBK CCZB
hVgti
2010 Volkswagen Golf
Post26-06-2021, 13:51    Subject: Check N75 regulation and power supply, MBK CCZB Quote
Hello everyone,
Can I use the testing method for the power supply to the N75 valve from this thread in the Diesel Engine Technology forum when troubleshooting a 2.0 TFSI EA888 engine in a Golf 6 GTI, or is a different approach required?
The thread: [url]/viewtopic.php?t=5020&highlight=n75+tastverhältnis[/url]
Is it also possible to check the correct settings of the engine control unit, or whether these are being correctly transmitted to the N75 valve?
I hope you all have a wonderful Saturday!
Greetings.
Hannes.
Golf 6 GTI - DSG - MKB: CCZB - MJ: 2011
Translated on 13-07-2026, 15:39.
Post28-06-2021, 18:19    Subject: Check N75 regulation and power supply, MBK CCZB Quote
Is it also possible to check the correct configuration of the engine control unit
Don't worry, it will be handled correctly.
"LG" translates to "Best regards" or "Sincerely" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 13-07-2026, 15:41.
No new posts P1065 - Power supply for engine management Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. MKB CCZB Performance dip between 2000 and 2300 RPM Gasoline Engine Technology
No new posts Fuel Injector Power Supply for MKB/BMN Engines Diesel Engine Technology
No new posts Power supply for Audi A4 B5 air conditioning Electrical Systems, Vehicle Electronics, Multimedia
No new posts ALH Load Disconnect Control System On-Board Diagnostics (OBD)
