jeepmatt1
dieselschrauber likes this. |
29-03-2021, 20:56 Subject: |
Hello Rainer, after investigating the Windows 10 dialog boxes, I now see in the Device Manager that the HEX-USB driver was actually not installed or updated. Whatever the reason...
I searched for drivers on the PC, installed them, and now the interface has been recognized!
Tomorrow, I'm going to the car. Should probably work now.
will report.
Thank you for the input; sometimes it can feel a bit silly when it turns out that the whole issue was just due to a small detail.
...I found myself better suited to XP...
Greetings from Ticino, Matteo
| Description: |
| File size: |
16.58 KB |
| Viewed: |
2361 times |
VW Lupo 3L, 2002
Daihatsu Copen 660 Turbo, 2004
Mitsubishi Pajero V20 2800 TD, 1997
VW T3 Doka 2,1 WBX, 1986
Mercedes 300 TE 4matic, 1991
Joined: 04/12/2002 Posts: 18121 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
29-03-2021, 23:50 Subject: |
Thank you for the feedback! Please ensure that the interface is not plugged in during the VCDS software installation.
Profile PM WWW Garage |
jeepmatt1
30-03-2021, 20:29 Subject: |
everything is working as expected. I can no longer be certain whether the interface was connected during installation, but it is certainly possible that it was.
Thank you again, now we will proceed with troubleshooting.
Best regards, Matteo
VW Lupo 3L, 2002
vag-driver Profi-Schrauber
30-05-2021, 0:38 Subject: |
Today I experienced the same problem on Windows 10. Interface not recognized.
I had to install the driver from the Ross-Tech directory.
Andreas
Florian320
2004 Audi Cabriolet Premium Support
27-06-2021, 13:50 Subject: |
Small update from me: After reinstalling the latest VCDS version on a new computer, I also had the problem that the driver was missing, and therefore the HEX-CAN USB was not recognized.
After manually updating the driver from the above directory, it worked immediately.
Profile PM Garage |
01-07-2021, 19:18 Subject: |
The installation package has been updated again; it seems there was a bug in the driver installation for older interfaces.
gtone
02-06-2026, 12:59 Subject: Same problem |
Hello everyone,
Unfortunately, I need to bump this post, as I'm now experiencing the same problem after updating to version 26.3.0. The interface is not found. The USB library version 03.02.07 does not seem to have a solution. The Device Manager is not working with it. Hex-USB + CAN Windows 11
02-06-2026, 13:36 Subject: Re: Same Problem |
gtone wrote: | Hello everyone,
Unfortunately, I need to bump this post, as I'm now experiencing the same problem after updating to version 26.3.0. The interface is not found. The USB library version 03.02.07 does not seem to have a solution. The Device Manager is not working with it. Hex-USB + CAN Windows 11 |
In the "Tree Menu" installation, install the "Legacy Drivers". These are normally disabled because they are no longer produced since 10 years.
Latest VCDS 26.3 from customer account, does the installation work otherwise?
Hi, Rainer
gtone
Oti likes this. |
03-06-2026, 19:55 Subject: |
Thank you in advance for the response, I believe the legacy drivers are missing in the latest version, is that possible?
| Description: |
| File size: |
34.92 KB |
| Viewed: |
137 times |
