Electric tailgate Passat B6
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
phgraf
Avatar-phgraf
Karma: +14 / -0   Thank you, like it!
Post27-08-2021, 11:31    Subject: Electric tailgate Passat B6 Quote
Ich habe an meinem Passat schon länger das Problem, dass die Heckklappe häufig wegen zu großem Widerstand je nach Außentemperatur nur mit Unterstützung auf oder zu geht. FehlThere are none.
While I doubt it, is there any way to adjust the current limit somehow?
Alternatively, I could just open the motors and check the brushes, but I really don't feel like doing that.
Are there any other possible solutions?
Otherwise, I would simply remove the engines permanently.
Okay, here's the translation:
Phillip.
Translated on 09-07-2026, 4:47.
vag-driver
dieselschrauber likes this.
Post27-08-2021, 12:04    Subject: Electric tailgate Passat B6 Quote
Is there anything related to this in the error memory? Is the mechanism operating smoothly?
Andreas
phgraf
Avatar-phgraf
Post27-08-2021, 12:09    Subject: Electric tailgate Passat B6 Quote
No and yes. By the way, the former was already mentioned in the original post.
Post27-08-2021, 14:03    Subject: Electric tailgate Passat B6 Quote
If the problem only occurs when going in one direction, it might still be related to the shock absorbers. However, if the problem occurs in both directions and the mechanics are okay, then the issue is likely with the motors.
Can you detect (hear or see) if there's a problem with only one of the motors in case of a malfunction?
I'm unsure whether the door latch with the automatic closing mechanism can remain if the car is modified. It's possible that it's controlled by the engine control unit, so you might also have to replace that.
I think I would just take a look at engines from scrapyards. That way, it would be a simple swap and not a retrofitting process.
Translated on 09-07-2026, 4:48.
No new posts Tapping noises, Audi A3 8P rear hatch/trunk lid Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C automatic tailgate and trailer operation Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat Tailgate Won't Open: Troubleshooting & Repair Transmission, Chassis, Body & Interior
No new posts Does the A6 C4 Avant rear door fit the rear door? Transmission, Chassis, Body & Interior
No new posts Electric Folding Mirror Control Ibiza 6K1 Price Transmission, Chassis, Body & Interior
