Audi 80 Avant 1Z: Dynamic Injection Timing Type?
Sandman999
Post27-11-2021, 19:09    Subject: Audi 80 Avant 1Z: Dynamic Injection Timing Type? Quote
Good evening.
leider weiß ich nicht, ob der von mir ausgewählte Typ im TDI-Graph für meinen Audi 80 Avant mit 1Z-Motor der Richtige ist. Bjis 02/1995.
The fuel injection pump has the number D31.
My problem is that there are 3 different types of the 1.9 TDI 1Z engine, and I'm not sure about the last two types.
The type I selected and configured shows "<1994> + AFD". If I enter this graph, the injection timing will be too late. This is probably not a problem for professionals like you, but I only work on things when I have to. icon_wink.gif
I would be very grateful if you could help me.
Andreas.
 File size:  220.21 KB
 Viewed:  447 times
 File size:  283.81 KB
 Viewed:  546 times
 File size:  48.94 KB
 Viewed:  438 times
Translated on 08-09-2026, 13:31.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-11-2021, 20:51    Subject: Audi 80 Avant 1Z: Dynamic Injection Timing Type? Quote
It's been a few years since I worked on a 1Z Audi (see my profile), but I'll still try to answer. With the 1995 model, you have the last version of the Audi 80 1Z, which included changes made during 1994, such as the turbocharger, 203 Nm of torque, a mass airflow sensor, and the MSA15 engine control unit. Mine was an MSA12, but the injection timing should be the same. The curve in the second image matches the one in my documentation (RLF). I also remember that the second curve applies to models from 1994 onwards.
The black and white version D09 was an intermediate step.
Translated on 08-09-2026, 13:33.
Sandman999
Post28-11-2021, 15:10    Subject: Audi 80 Avant 1Z: Dynamic Injection Timing Type? Quote
Hello.
Great, thank you very much. I'll try that out. That's why it was running so slowly. icon_redface.gif
By the way, I cleaned the MSW. The reason was actually that the seal was leaking.
Currently, the MSW (likely referring to a machine setting) is set to 4.6 - 4.8 mg/hub. I will fine-tune it further towards 3/4 once I have corrected the injection start.
Andreas.
Translated on 08-09-2026, 13:34.
Post28-11-2021, 15:45    Subject: Audi 80 Avant 1Z: Dynamic Injection Timing Type? Quote
Currently, the MSW is set to 4.6 - 4.8 mg/hub.
Optimal.
Translated on 08-09-2026, 13:35.
Sandman999
Post16-12-2021, 16:32    Subject: Audi 80 Avant 1Z: Dynamic Injection Timing Type? Quote
Hello.
I have now correctly adjusted the injection timing, and I couldn't resist tweaking the quantity control. icon_biggrin.gif
Currently, the injection volume is 4.0-4.2 mg per dose.
The Avant is now running perfectly. No more jerking, and the acceleration is great. I'm looking forward to seeing what the fuel consumption will be.
 File size:  100.06 KB
 Viewed:  248 times
Translated on 08-09-2026, 13:36.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Audi A6 4F Avant Kombiinstrument, VAG-COM. On-Board Diagnostics (OBD)
No new posts Kosten: Audi 80 Avant - Querlenker Transmission, Chassis, Body & Interior
New posts Audi 80 Avant Wheel Alignment - Caster Adjustment Transmission, Chassis, Body & Interior
