Exchange Pressure Can
ansc89
Post04-02-2022, 15:24    Subject: Exchange Pressure Can Quote
I want to replace the pressure sensor on my Polo 6R, 1.6 TDI, CAYB, from 2011, due to an electronic fault. According to the repair manual, I should use the "guided troubleshooting" to correctly adjust the lever. However, I don't have a VAS (only VCDS), so this is not possible. My control unit also does not support the "data block" function, so I cannot access block 120. Does anyone have any ideas on how I can correctly adjust the pressure sensor or the control lever? I only found the measurement "Turbocharger High-Pressure: Actual Raw Voltage" in VCDS, which shows a value of 4.70 V when the control lever is completely retracted and 1.36 V when the control lever is completely extended.
Duese
Post04-02-2022, 18:22    Subject: Exchange Pressure Can Quote
What charger do you have, and what is the capacity? Pictures?
Best regards, Rainer
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts TDI Pressure Canister 2.5L Diesel Engine Technology
No new posts Test LDR Pressure Canister Diesel Engine Technology
No new posts Aerosol Can on Spray Booth Diesel Engine Technology
No new posts Pressure Vessel 1Z - Larger Size Diesel Engine Technology
