brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
20-04-2022, 13:10 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hello everyone,
For my 1.4 Polo TDI, I used the Hazet 2588/3 tool set for the timing belt replacement. That worked great.
What part number do I need for the 2.0CR engine for KW, NW, and HDP?
Brezelmann01
Herbert Profi-Schrauber
dieselschrauber and brezelmann01 likes this. |
20-04-2022, 14:54 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hi Brezelmann,
I don't use a single, all-in-one solution for my CI/CD; instead, I use individual tools.
- KW Stop T10050;
- Centering pin 3359, 2 pieces, for inner wheel and outer wheel (or mandrel, drill bit d = 6 mm).
- Counterweight for the N (homemade).
- Very long key for turning the crankshaft (homemade - ring wrench with a flat bar attached).
- same, for relaxing the tensioner roller of the KRR system;
The kW stop value may vary from engine to engine, and it looks different in the Golf 7 with a 1.6L TDI engine. Ask about RLF.
dieselschrauber likes this. |
22-04-2022, 10:27 Subject: Common Rail Tool Set for Timing Belt Replacement |
Okay, so the KW stop and the alignment pin need to be taken over.
OEM T10050 = Hazet 2588-1
OEM 3359 = Hazet 2588-3
I just need to buy one more marking pin. I'm going to use original/Hazet parts here, as this one is hollow-drilled, presumably to allow air to escape from the guide.
Thank you!
22-04-2022, 14:44 Subject: Common Rail Tool Set for Timing Belt Replacement |
You'll need two probes, one for the front wheel and one for the rear wheel. A simple 6 mm pen will really do the trick.
04-06-2022, 10:05 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hi!
Is there a recommendation for a reasonable camshaft holding tool for home use that is below the price range of Hazet?
Brezelmann01
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
dieselschrauber and Herbert likes this. |
04-06-2022, 13:21 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hi Brezelmann,
Build your own counterweight. Material: €20, Time required: 30 minutes.
It has been providing its service to me for almost 10 years.
| Description: |
| File size: |
3.89 MB |
| Viewed: |
476 times |
| Description: |
| File size: |
3.07 MB |
| Viewed: |
288 times |
Profile PM Garage |
04-06-2022, 14:00 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hello!
DIY - You'll need a flat bar, two screws with a head diameter that fits the holes in the crankshaft pulley (top of the image), and two pins that fit the holes in the harmonic balancer (bottom of the image).
| Description: |
| File size: |
6.27 MB |
| Viewed: |
224 times |
![Common Rail Tool Set for Timing Belt Replacement WP_20220604_13_55_21_Pro[1].jpg](download.php?id=14269)
05-06-2022, 13:09 Subject: Common Rail Tool Set for Timing Belt Replacement |
Hmm. Okay. Do it yourself. Actually, I didn't want to, as I currently don't have enough time and I also don't know the dimensions.
Brezelmann.
05-06-2022, 14:39 Subject: Common Rail Tool Set for Timing Belt Replacement |
Caliper? I mean, I must have gotten the dimensions from somewhere.
07-06-2022, 19:21 Subject: Common Rail Tool Set for Timing Belt Replacement |
Could you please tell me the thorn diameter you use for the counter-holder? You can't just easily measure the pressure without installing an additional pump and removing all the extra components.
Thank you!
08-06-2022, 9:00 Subject: Common Rail Tool Set for Timing Belt Replacement |
I have M10 and M8 screws (with the M10 screw turned down to 8mm) installed.
VG
Thilo.
Profile PM Garage |
