trubenba
Joined: 08/13/2022 Posts: 3 Karma: +0 / -0 Location: Ursensollen
13-08-2022, 16:43 Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L |
Hello, I'm having the following problem: The air conditioning stopped working. The compressor was replaced and recharged. The compressor is working, but the interior isn't getting cold. When I read the error codes, the following message appears: "Temperature sensor, evaporator, defective" and the error cannot be cleared. Can anyone tell me where this temperature sensor is located and how to replace it? Passat 2,8 APD 4 Motion
Translated on 03-07-2026, 15:21.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber likes this. |
13-08-2022, 17:39 Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L |
Please provide the exact error codes and descriptions from the VCDS scan.
There's a sensor that you can see when you remove the pollen filter and look up towards the blower motor. It's accessed from inside the car; you need to remove the panel underneath the glove compartment and reach up. It requires a quarter turn and then you can pull it out, but it's quite fiddly. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 03-07-2026, 15:22.
Profile PM Garage |
trubenba
14-08-2022, 7:08 Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L |
That is the error code: 332, Thermistor, Evaporator. Passat 2,8 APD 4 Motion
Translated on 03-07-2026, 15:23.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
14-08-2022, 7:44 Subject: Re: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L |
trubenba wrote: | | This is the error code: 332. It indicates a problem with the temperature sensor in the evaporator. |
Okay, I didn't grow up with a silver spoon in my mouth. If something broke down for me, I knew that either I had to fix it myself, or the thing was junk, with all the consequences that entailed. Broken car -> no car, for example.
And when I asked someone for help, I was very, very happy to receive a sensible answer.
That's why I've always tried to express myself politely and clearly, and then to express my appreciation for the help I received.
We are in the year 2022, and we no longer need to carve things into stone tablets; almost everyone possesses a brain prosthesis, which we call a cell phone.
Almost all mobile phones have the ability to take pictures, for example, of error messages.
Translated on 03-07-2026, 15:24.
Profile PM WWW Garage |
trubenba
14-08-2022, 10:14 Subject: Passat 3BG air conditioning system |
Okay, thank you again to everyone who put in the effort to troubleshoot the issue with the error code 332, which relates to the evaporator temperature sensor. I found the error.
You wouldn't believe it, but it's true. It was due to the control panel of the air conditioning system. I once replaced it because the lighting was malfunctioning. Somewhere, I read that there's a difference in the programming or something like that between the two suppliers, Hella and VDO. I seem to remember that. So, I swapped the control panel back to the old one. The self-diagnosis test for the climate control showed no errors, and the climate control function is working properly again. Passat 2,8 APD 4 Motion
Translated on 03-07-2026, 15:26.
15-08-2022, 6:23 Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L |
Okay, so the result is: You replaced the control panel of the air conditioning system with an incompatible one, which caused an error. Okay.
Translated on 03-07-2026, 15:27.
