TDI AWX Oil Pressure Sensor for VW C5
Grausi
Post20-08-2022, 9:07    Subject: TDI AWX Oil Pressure Sensor for VW C5 Quote
Hello everyone,
As mentioned above, I want to see oil pressure in addition to boost pressure. That's why my question: The oil filter housing seems to have a blank plug. Can this be used instead of an adapter?
Thank you icon_smile.gif.
Translated on 21-08-2026, 20:13.
Post20-08-2022, 9:39    Subject: TDI AWX Oil Pressure Sensor for VW C5 Quote
I'm not sure which blind plug you mean. Do you have a picture?
For the AWX engine, there is an oil cooler kit that connects to the oil filter via a spacer flange.
Since that's necessary, it doesn't seem to be quite as simple as it appears.
You can definitely reduce oil pressure where the original pressure sensors are screwed in.
There might also be limit switches with integrated sensors, but I'm not sure about that; it would be great if they existed.
Translated on 21-08-2026, 20:14.
Grausi
Post20-08-2022, 9:53    Subject: TDI AWX Oil Pressure Sensor for VW C5 Quote
Hello Rainer,
Thank you for your quick response. I'm not near the car right now, but maybe it can be identified from the pictures (the drawing in the upper left corner).
I thought adapters often take up a lot of space and are frequently not airtight.
[Edit Admin: Bitte nur Bilder wofür man die Rechte hat!]
Best regards.
Marc.
 File size:  38.56 KB
 Viewed:  327 times
Translated on 21-08-2026, 20:15.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post20-08-2022, 13:58    Subject: TDI AWX Oil Pressure Sensor for VW C5 Quote
Hi there,
In the photo, you can see the flange connecting to the engine at the bottom, the connection to the oil cooler on the right, and the flange for the oil filter on the left. The oil pressure switch is screwed in. So, that's like diagram image 2 from the parts catalog, rotated 90 degrees counter-clockwise. Where would a blind plug be located?
The wiring diagram shows either the oil pressure switch (as installed in the photo) or a screw.
Translated on 21-08-2026, 20:17.
dieselschrauber and Herbert likes this.
Post20-08-2022, 19:52    Subject: TDI AWX Oil Pressure Sensor for VW C5 Quote
If there is enough space, install a T-fitting where both can be screwed in.
Translated on 21-08-2026, 20:18.
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resetting the service interval display on a Volkswagen Go... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Service Interval Display: How to Reset Diesel Engine Technology
No new posts KM Anzeige im Motorsteuergerät On-Board Diagnostics (OBD)
No new posts GRA Indicator in Dashboard: Meaning & Troubleshooting Diesel Engine Technology
No new posts vag-com and service interval indicator Diesel Engine Technology
