CXXB Injectors: Loud Backfire & Rough Running
DeeJay80
Post22-08-2022, 7:19    Subject: CXXB Injectors: Loud Backfire & Rough Running Quote
The car (Golf 7, manufactured in 2016, 1.6 TDI 110 hp) had a problem with the diesel fuel pump.
A refurbished diesel pump was installed, along with injectors from the same supplier. The fuel rail was replaced, and the fuel lines and tank were flushed.
Now the problem is that the car is making a very loud knocking noise (which is getting worse) and it's also running roughly at idle again.
The injectors from that supplier don't seem to have been the best choice.
I'm now going to use VCDS to find out which injector(s) are responsible for the problem.
However, there is no deviation in the fuel injection quantity among the extended measurement values, only a deviation in the injection duration, which I find less useful.
The Delphi Tester isn't helping me either. Does the CXXB not have a quantity discrepancy?
Translated on 16-10-2026, 5:42.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post22-08-2022, 8:10    Subject: CXXB Injectors: Loud Backfire & Rough Running Quote
"On my 1.6L TDI DDYA engine, this is the case. You can directly infer the fuel injection quantity deviation from the reported injection time deviation."
Ask Autoscan?
Translated on 16-10-2026, 5:44.
Post22-08-2022, 8:18    Subject: CXXB Injectors: Loud Backfire & Rough Running Quote
The system may not have been 100% free of chips.
No new posts AHF MKB: Troubleshooting Idle Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD: Severe Engine Misfire During Acceleration Diesel Engine Technology
No new posts Octavia 1.6 TDI CXXB has jerky movements, clunks, and int... Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI Injector Problems: Golf 7 Variant 1.6 CXXB Diesel Engine Technology
No new posts Sharan 1.9 TDI 4Motion: Loud Rumble When Accelerating? Diesel Engine Technology
