OBD-Tuning beim Ibiza ASZ | Posts 16+
Go to page: Previous  1, 2
Steve
Post11-11-2003, 0:40    Subject: Quote
Hello everyone...
You don't need to worry 'yet' about the arbitrary flashing of ECUs.
Thinking about...
To the best of my knowledge, this flashing process is currently only available for the 3L Lupo.
and were performed as part of a recall campaign.
Steve.
Gremlin
Post11-11-2003, 9:28    Subject: Quote
I can still imagine that after the update, one could simply run their own update again, if everything necessary is available.
But the easiest thing is probably to make a really big detour around every authorized repair shop. icon_wink.gif
Well... it's a questionable thing...
Firmware updates are usually installed to achieve an improvement.
This can affect all aspects of the engine's operation. Some updates are certainly beneficial, so in those cases, you should only change the calibration tables and avoid downgrading the rest of the firmware.
'By the way, I haven't seen any TSOP sockets yet... but with the right soldering tools, these parts aren't a problem. However, I wouldn't let just anyone work on such an IC unless they've already demonstrated that they can solder.'
CU Gremlin.
Rudi
Post11-11-2003, 11:59    Subject: Quote
You are right about the soldering icon_cool.gif.
Baseboards already exist (e.g., from Yamaichi); however, they all...
They do not have an SMD footprint; instead, they are soldered in.
Best regards, Rudi.
Gremlin
Post11-11-2003, 12:31    Subject: Quote
Best regards, Rudi
Do you mean this one? http://www.yamaichi.com/pdf/prot/pt03_ic197.pdf
They should actually fit... I'm going to go check on the lab rats.
CU Gremlin.
Rudi
Post11-11-2003, 13:52    Subject: Quote
Hi.
I hadn't seen those before. Here, the footprint must also be prepared accordingly, otherwise the solder pads will be very undefined.
Best regards, Rudi.
 File size:  8 KB
 Viewed:  2332 times
Gremlin
Post11-11-2003, 18:51    Subject: Quote
However, the footprint must also be prepared accordingly, otherwise the solder pads will be very undefined.
It would definitely be tight, but who knows...
If someone sends me a ;-)STG, a socket, and an IC, I'd be happy to try it out.
CU Gremlin.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G62 at the ASZ in the Seat Ibiza Diesel Engine Technology
No new posts Ibiza 6K Brake Pads: Replacement & Installation Transmission, Chassis, Body & Interior
No new posts Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Transmission, Chassis, Body & Interior
No new posts Ibiza: Climatronic Diagnosis Mode Guide Transmission, Chassis, Body & Interior
