Valve not programmed and control unit not coded | Posts 16+
Go to page: Previous  1, 2
Garage83H23
Post13-02-2023, 22:08    Subject: Valve not programmed and control unit not coded Quote
Hello, I'm experiencing the same issues with an Audi A8 4H. The control unit cannot be calibrated; it's being aborted for safety reasons, and the coding attempts have also been unsuccessful. The problem is that someone used a Chinese VCDS to modify the Audi, specifically to lower it. Since that person worked on the car, the Audi is now only lowered in the front. Additionally, the message "Vehicle height exceeded" is displayed. Every attempt to resolve the problem has so far been unsuccessful. Before the Chinese VCDS was used, the suspension system was working perfectly; everything was functioning correctly. I would be very grateful if someone could give me some advice on how to solve this problem, as the Audi has been sitting idle for 3 months.
Post13-02-2023, 22:21    Subject: Re: No control unit learned and ECU not coded Quote
Garage83H23 wrote:
Hello, I'm experiencing the same errors with an Audi A8 4H. The control unit cannot be programmed. It's being aborted for safety reasons, and the coding is also unsuccessful. The problem is that someone messed around with the Audi using a Chinese VCDS and tried to lower it so much that ants would have their heads shaved, and the car bounces like Herby. Since that person worked on it, the Audi is only very low in the front. And the message "Vehicle height exceeded" is displayed. Every attempt to solve the problem has so far been unsuccessful. Before the Chinese VCDS was used, the suspension worked perfectly; everything was functioning correctly. If someone can give me advice on how to solve this problem, I would be very grateful, as the Audi has been sitting there for 3 months.
The "Motivation" field is missing data for either the automatic scan or the customer status.
matthias.stender
Karma: +9 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-02-2023, 8:21    Subject: Control unit cannot be programmed Quote
Hi.
I would try to manually adjust the front and rear axle heights using VCDS to a usable level. Then, as described in the instructions, I would clear the values and enter the default values, such as 415 for the front and 405 for the rear, and then calibrate. Perhaps it will then revert to a mode that can be properly calibrated.
It's crucial to follow the exact sequence specified in the instructions, otherwise the programming will fail. I've unfortunately encountered the same problem again, but the cause is a level regulator that's malfunctioning. I ordered a new one and am waiting for another attempt...
Matthias.
Fehler sind dafür da nur einmal gemacht zu werden
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts How to reset DSG from Golf 7R, Audi S3 8V to factory sett... Gasoline Engine Technology
No new posts Air suspension Transmission, Chassis, Body & Interior
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
No new posts DSG Basic Settings Audi DL501 vs. VW DQ500 On-Board Diagnostics (OBD)
