Seal Tandem Pump: How To & Best Practices
Lothar
Post11-03-2004, 14:52    Subject: Seal Tandem Pump: How To & Best Practices Quote
The tandem pump (pump-injector) in my Golf is leaking. Before I take it apart to have it repaired, I would like to understand exactly how it works.
I would appreciate any relevant information, whether it be drawings, explanations of functionality, specifications, or potential sources of error.
Has anyone else experienced this problem?
Lothar.
Translated on 07-09-2026, 17:05.
PowerSound3L
Post11-03-2004, 16:41    Subject: Seal Tandem Pump: How To & Best Practices Quote
hi,
It seems this problem occurs more often.
Meanwhile, there is a revised version with different seals.
'However, there apparently isn't a replacement seal available, so the entire pump needs to be replaced.'
That's all I know about it.
greetings
Translated on 07-09-2026, 17:06.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post13-09-2004, 23:00    Subject: Seal Tandem Pump: How To & Best Practices Quote
hi!
Unfortunately, my injection pump is also getting wet, and the diesel is spreading as a very thin, creeping, and sticky film all over the engine icon_evil.gif. As far as I can tell, it is definitely diesel and not engine oil. Therefore, I would like to revisit Lothar's question and ask if anyone has already attempted to disassemble it. I am familiar with the operation of the pump from the SSP 209, but I have unfortunately never seen an opened pump.
It would be annoying if half of the contents spilled out when I open it... Does anyone have any photos or reviews?
Unfortunately, besides the seals between the fuel injection pump and the pump body, nothing else is available. Is it possible to permanently seal the pump itself using sealant? Which sealant would be best? It absolutely must be fuel-resistant.
"Thank you!"
Dirk.
Translated on 07-09-2026, 17:07.
Marco1001
dieselschrauber likes this.
Post23-02-2023, 21:39    Subject: Seal Tandem Pump: How To & Best Practices Quote
Sealing from the outside is not a problem! Simply remove the yellow zinc-plated lid.
Wipe off any diesel and make sure everything is completely clean and free of grease (you can even reuse the old O-ring, just remove it and make sure everything is clean). Then, apply a thin layer of Reinzosil sealant all around the circumference, reattach the cover, and you're done!
No parts will fall out if you work carefully.
Best regards to everyone.
Translated on 07-09-2026, 17:09.
dieselschrauber and E30_V8 likes this.
Post24-02-2023, 18:59    Subject: Seal Tandem Pump: How To & Best Practices Quote
No parts fall out when working carefully.
Don't use it to fill the gap, especially if you're not experienced with sealants. Silicone has no place here; there are sealant kits specifically designed for this purpose.
Translated on 07-09-2026, 17:10.
No new posts Seal AGR cooler bypass valve on CR-V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seal Hubdüse SWA: How to & Best Practices Transmission, Chassis, Body & Interior
No new posts tandem pump Diesel Engine Technology
No new posts Valve Cover Gasket: Reviews & Sealing Tips (ASZ) Diesel Engine Technology
No new posts Fuel Pressure Sensor for Tandem Pump On-Board Diagnostics (OBD)
