VCDS 22.10 Update & HEX-V2 Firmware Update
dieselschrauber likes this.
Post13-05-2023, 14:47    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
During the interface test of the newly installed VCDS RKS 22.10, a firmware update for the HEX-V2 is reported as necessary.
Will the older VDCS versions still work, specifically version 18.9?
I'm using this version because the coding interface is significantly more user-friendly.
Herbert likes this.
Post13-05-2023, 15:45    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
Hello Herbert,
I'm not sure if the 18.x version is running with the current firmware, probably not.
Within the VCDS installation directory, you will find LCode.exe (new) and LCode-Classic.exe (old).
If you prefer the "Classic" version, simply choose that one. The file "lch-loc.txt" contains the program name used for the long encoding, and it will then execute the .exe file specified in that file.
Post13-05-2023, 16:03    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
I'll try that out using the existing version 20.
Does the service reset function work for the Golf 7 with the 22-10 device? Otherwise, I'll stop.
Herbert likes this.
Post13-05-2023, 16:17    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
Herbert wrote:
Does the service reminder reset function work for the Golf 7 on the 22-10?
Hi Herbert,
It most likely involves adaptation mechanisms.
Post13-05-2023, 21:41    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
I know icon_wink.gif. I would have been interested in the complete SRI menu. But I'll get to that later; for now, I'm going to implement your suggestion about LCode-classic.
dieselschrauber, Turbinchen and E30_V8 likes this.
Post14-05-2023, 15:57    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
The change to the menu view to LCode-Classic worked, thank you for the tip. icon_smile_thumb_up.gif
It also works with version 22.10, and version 18.9 still functions with the new firmware (although I don't actually need it with LCode-Classic).
What's not working is the "service reminder" function via the menu for the Golf 7. The error message essentially says "We don't have any data....". icon_peinlich.gif icon_blame.gif Guys and girls, the car is from the model year 2018, not exactly rare, and it's 2023. Maybe you could ask about it in this forum.
I'll address the "service reminder" feature in the menu of the A4 8K and possibly other models in a separate thread.
Post14-05-2023, 18:55    Subject: VCDS 22.10 Update & HEX-V2 Firmware Update Quote
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Update, Firmware Update - Troubleshooting On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS RKS Update: MAC & Windows XP Support On-Board Diagnostics (OBD)
No new posts VCDS Update: Version 17.8.0 Released On-Board Diagnostics (OBD)
