Actuator diagnosis for troubleshooting: Malfunction of left-side climate control
stolley
Karma: +38 / -1   Thank you, like it!
Post14-05-2023, 20:36    Subject: Actuator diagnosis for troubleshooting: Malfunction of left-side climate control Quote
Hello everyone,
In my Golf Sportsvan (year of manufacture 2016), which I bought in early December 2022, I noticed today that when the air conditioning is turned on full, very warm air is blowing out of the vents on the dashboard on the driver's side.
I suspect that a servo motor for a ventilation flap is defective.
Therefore, I would like to verify/document this using an actuator diagnostic test via VCDS.
I had previously attempted this, but I encountered spontaneous difficulties in selecting or interpreting the correct measurements.
Can anyone help me with that? Which values from which actuator do I need to check?
Thank you all!
Volker.
Here are the vehicle specifications:
Vehicle type: AU-VW37 (5Q0)
Vehicle Identification Number: WVWZZZAUZGW56XXXX
Translated on 03-07-2026, 23:47.
Post14-05-2023, 21:07    Subject: Actuator diagnosis for troubleshooting: Malfunction of left-side climate control Quote
Hi.
It would be interesting to know which types of actuators VCDS offers for control. Vehicle data is not helpful; instead, a car scan and a wiring diagram for the vehicle are needed.
Translated on 03-07-2026, 23:49.
stolley
dieselschrauber likes this.
Post15-05-2023, 20:32    Subject: Actuator diagnosis for troubleshooting: Malfunction of left-side climate control Quote
Hello Rainer,
Thank you very much for your feedback!
I've attached a few screenshots. It also includes a recording of the diagnostic data for the left temperature control valve.
To me, it looks like this is working correctly. Could the problem described be a temporary glitch?
Here's the Autoscan result:
Sunday, May 14, 2023, 3:32:22 PM: 0.25065
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64 (using VMWare).
VCDS Version RKS 22.10.0.1
Data as of: 20221224 DS344.0
Vehicle Identification Number: WVWZZZAUZGW56XXXX Vehicle Registration Plate:
Mileage: 117,601 km. Repair order: 230514.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
Vehicle Identification Number: WVWZZZAUZGW56XXXX Mileage: 117,601 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
19-Diagnostic interface -- Status: Error 0010.
42-T voltage regulator. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-core electrical. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CXXB) Label file: . DRV\04L-907-309-V1.clb
Part number SW: 04L 906 056 CM, HW: 04L 907 445 B.
Part: R4 1.6L TDI H06 9471
Revision: 22004001
Encoding: 0111401243241D092000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI03004L906056CM 004010
ROD: EV_ECM16TDI03004L906056_004.rod
VCID: 7AFDC540FDBEB05DCC-802F
VINID: 9E69EAAAA465A979C51840C40839845B42
No error codes found.
Readiness: Not available.
Address 03: Brake Electronics (J104)
Label file: DRV\5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 AF, HW: 3Q0 907 379 F.
Component: ESC H42 0625
Revision: 00000000 Serial Number: 63165000002562
Encoding: 03FA62A124268970077A060441C525C0462491E06082A4F310400078C002
Operating number: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7EF5C950E1969C7DF0-802B
Address 08: Climate Control/Heater (J255) Label file:| DRV\5G0-907-044.clb
Part number SW: 5G0 907 044 BD Hardware: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Encoding: 08020104202100011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6ADDF5008D1E00DD3C-803F
Control unit for fresh air blowers (front).
Refrigerant pressure/refrigerant temperature sensors:
Air quality sensor:
Address 09: Central Electronics (J519) Label file:| 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 086 AK. Part number HW: 5Q0 937 086 AK.
Part: BCM PQ37BOSCH 028 0162
Revision: -------- Serial Number: 86582311152745
Encoding: 00000846C24100DB4BE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 0303B8A48A74F1959F-8057
Control unit for windshield wiper motor:
Subsystem 1 - Part number SW: 517 955 119 HW: 517 955 119 Label file: DRV\5QX-955-119-V1.CLB
Part: WWS 151028 042 0596
Serial number: 151110151429
Encoding: 0E4DDD
Humidity source: indoors:
Subsystem 2 - Part number SW: 8U0 955 559 HW: 8U0 955 559 Label file: DRV\8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 71281002
Address 10: Parking Assist 2 (J446) Label file8) DRV\5Q0-919-294.clb
Part number SW: 5Q0 919 294 K, HW: 5Q0 919 294 A.
Component: PARKING ASSIST 8K H03 0054.
Revision: -------- Serial Number: 39391532703676
Encoding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 438378A4CAF43195DF-8017
Address 13: Distance control (J42:| Label file:| 5Q0-907-572-V1.clb
Part number SW: 5Q0 907 572 F. Hardware: 5Q0 907 572 F.
Part: ACC Bosch MQB H05 0400
Serial number: 20111503273778.
Encoding: 00000100FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3A7D0540BD3E705D8C-806F
Address 15: Airbag (J234) Label file:| DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, HW: 5Q0 959 655 D.
Part: Airbag VW20 015 0388
Serial number: 003F6R197RHQ
Encoding: 98CCC000000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418F72ACD0E82385CD-8015
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: ----------- HW: 480 001 011 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000BD6A87715
Encoding: 2D2D2D
Crash sensor for the side airbag, passenger side:
Subsystem 2 - Part number: SW: ----------- HW: 480 001 011 15
Component: SideSensor_Pf 001 0887
Serial number: 358670000002FB4D7713
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 480 401 711 15
Part: SideSensor_Dr 001 6149
Serial number: 35165029F1E34434B2FL
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: ----------- HW: 480 401 711 15
Component: SideSensor_Pr 001 6149
Serial number: 35265029B1E34434233+
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number SW: ----------- HW: 480 401 611 15
Component: FrontSensor_D 001 6149
Serial number: 3556502A31E34435325/
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527) Label file:| DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 FT, HW: 5Q0 953 549 F.
Component: Steering. Module 003 0120.
Revision: -------- Serial Number: 23111504220828
Encoding: 0400
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 0D179E9CDC30B7E5F9-8059
Address 17: Terminal block insert (J285) icon_neutral.gif Label file: DRV\5G0-920-XXX-17.clb-SRI3
Part number SW: 517 920 751 A, Hardware: 517 920 751 A.
Part: KOMBI 302 6420
Encoding: 07A402002380000801886A011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 1625F1F0E9E6743D48-8043
"1 error found:"
16777018 - Functionality restriction due to communication error.
U1110 00 [008] - -
[New feature!] Extended UDS error code information is only supported by current hardware generations.
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6.
Error frequency: 1
Lost Count: 15
Mileage: 117,319 km
Date: 2023.05.04
Time: 07:51:42
Address 19: Diagnostic interface (J533) Label file:| DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AJ, HW: 5Q0 907 530 F.
Part: GW MQB High 128 1244
Revision: -------- Serial Number: 0004235828
Encoding: 030100041F087300FB000248080F000100010500000000000000000000000
GVL: 01543C0000000000400C80000000480000000000000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79FFDA4CF8B8BB45C5-802D
Generator:
Steering wheel control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 5G0 959 442 J HW: 5G0 959 442 J Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29150002309380025473.
Encoding: 28FFFF
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 G, HW: 5Q0 915 181 G.
Part: J367-BDM Hella H04 8050
Serial number: 0771508403
"1 error found:"
66052 - Infotainment CAN.
U0065 00 [008] - No communication.
Error priority: 2.
Error frequency: 1
Lost Count: 25
Mileage: 117,601 km
Date: 2023.05.14
Time: 15:23:47
Supply voltage, terminal 30: 12.3 V.
Terminal 15: off.
Address 42: Turntable electrical. Driver (J386) Label file:| 5QX-959-X93-42.clb
Part number SW: 5Q0 959 593 E, HW: 5Q0 959 593 B.
Part number: TSG FS 020 0041.
Serial number: 290915BIR02096
Encoding: 00310320D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Rear driver's side door hinge.
Subsystem 1 - Part number SW: 5Q0 959 811 HW: 5Q0 959 811 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008160551
Encoding: 110000
Address 44: Steering Assist (J500) Label file:| DRV\5Q0-909-143.clb
Part number SW: 5Q0 909 143 K, HW: 5Q0 909 143 E.
Part: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000511524
Encoding: 01000010005000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
VCID: 3B730044B204495597-806F
Address 52: Power supply. Co-driver. (J387) Label file:| 5QX-959-X92-52.clb
Part number SW: 5Q0 959 592 E, HW: 5Q0 959 592 B.
Part number: TSG BFS 020 0041.
Serial number: 021015BJ108868.
Encoding: 00310120DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D7DA0D5EE389DD4-8017
Rear passenger side airbag module:
Subsystem 1 - Part number SW: 5Q0 959 812 HW: 5Q0 959 812 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000008199978
Encoding: 090000
Address 5F: Information selection. I (J794) Label file
5G0-035-MIB-STD2.clb
Part number SW: 3Q0 035 846 Hardware number: 3Q0 035 846
Part number: MU-S-N-ER 820 0627
Serial number:
Encoding: 02730901FF00000051110001000808001F01008401200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6ED5F910B1F6ECFD60-803B
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 3G0 919 605 D, HW: 3G0 919 605 D.
Part: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R3181904
Data carriers:
Subsystem 2 - Part number SW: V03 959 820 CL HW: -----------
Component: ECE DL2 23/24 --- 2010
Serial number: --------------------
End----------------------------(Duration: 04:35)-----------------------------
http://shop.dieselschrauber.org/en
 File size:  141.48 KB
 Viewed:  765 times
 File size:  168.09 KB
 Viewed:  837 times
 File size:  175.14 KB
 Viewed:  779 times
Translated on 04-07-2026, 0:18.
Post16-05-2023, 6:16    Subject: Actuator diagnosis for troubleshooting: Malfunction of left-side climate control Quote
Well, "Temperature flap control motor, left/right" sounds very promising. icon_biggrin.gif
Translated on 04-07-2026, 0:49.
No new posts Variable valve timing malfunction General Tips
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 AC Compressor Problems: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Actuator diagnostics on the 1Z On-Board Diagnostics (OBD)
No new posts Actuator Diagnosis: Questions and Answers Diesel Engine Technology
No new posts Airbag actuator diagnosis On-Board Diagnostics (OBD)
