LED control unit for daytime running lights
Karma: +2 / -2   Thank you, like it!
Post26-06-2023, 16:11    Subject: LED control unit for daytime running lights Quote
Good day. The control unit for the left LED daytime running light is defective on my Audi A3 8V1.
Question: Do I also need to code this, and if so, how?
Thank you in advance for your answers.
Translated on 22-07-2026, 10:26.
Post26-06-2023, 21:15    Subject: LED control unit for daytime running lights Quote
When you post an Autoscan result, it shows which control units are installed and their coding.
If a control unit is defective, it may no longer respond to diagnostic requests. Therefore, it is advisable to perform an automotive scan and archive the results after purchasing a vehicle.
Typically, a replacement control unit with the same VAG part number is used, and the coding from the old control unit is transferred to the new one.
Translated on 22-07-2026, 10:27.
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts The climate control display is no longer showing anything. On-Board Diagnostics (OBD)
No new posts 1Z measurable increased consumption after removal of the ... On-Board Diagnostics (OBD)
No new posts Tagfahrlicht per VAG-COM On-Board Diagnostics (OBD)
No new posts Gedimmtes Tagfahrlicht Transmission, Chassis, Body & Interior
