1.9 TDI AWX Engine Noises Under Load
crapSen
2005 Skoda Superb
Post25-06-2023, 18:50    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Hi, I could use your help.
Yesterday, while driving my Superb 1.9 TDI AWX with approximately 440,000 km, I heard a noise that I didn't recognize after a long highway drive.
At partial load and even more so at full load, there are noises coming from the engine compartment, located in the center towards the right side of the vehicle. It sounds like slowly releasing air from a balloon.
"The turbocharger has approximately 300,000 km on it. Oil changes have been performed regularly. I'm not an aggressive driver, and I've always made sure to run the engine for a few minutes at the end of a trip to allow it to cool down properly."
Unfortunately, I can't capture the sound in the video. The noise is not reproducible when the device is stationary, and it is definitely not a typical turbo whistle sound.
The wave from the turbo doesn't have any play.
Here's what the turbo looks like; those small deposits inside the turbine wheel have been there for a long time. (see attachment)
The sounds are similar to these:
Maybe someone here has some advice or a tip.
Daniel.
 File size:  252.85 KB
 Viewed:  527 times
Translated on 03-09-2026, 16:20.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
crapSen likes this.
Post25-06-2023, 20:36    Subject: TDI Turbo Noise: AWX Engine Problems & Solutions Quote
Hi Daniel,
Spontaneously, and quickly, I would suspect a (small) leak somewhere in the charge air duct. Given the mileage, the plastic pipe might be cracked or damaged in one place.
"It might be worn out. Or the quick connector on the AGR valve might be leaking. Is there a loss of power? What does the error memory/OBD scan show?"
crapSen wrote:
At partial load and even more so at full load, there are noises coming from the engine compartment, located on the right-center side in the direction of travel.
As far as I remember, the engine in the Superb is mounted longitudinally, like in the Passat, which would explain the direction of the noise.
The video from the link is no longer available...
Best regards, Richard.
Polo V 1,6 Tdi (CAY)
Translated on 03-09-2026, 16:23.
crapSen
2005 Skoda Superb
Post25-06-2023, 20:44    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Hello Richard,
Thank you for your response.
There is no loss of power. No warning lights or other unusual indications.
Yes, the engine is mounted longitudinally, so the timing belt is located directly behind the grill (I always get confused about that).
Daniel
Translated on 03-09-2026, 16:24.
Post25-06-2023, 20:49    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
If someone needs help, they can record a video with their phone instead of providing dead links, which would only create extra work for me.
It can't be that difficult to read the introduction here in the forum. icon_idea.gif
Translated on 03-09-2026, 16:25.
crapSen
2005 Skoda Superb
dieselschrauber, Hutfahrer and Turbinchen likes this.
Post25-06-2023, 21:34    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Hello Rainer, first of all, sorry about the broken link...
I actually tried to record my own video of the noise, but unfortunately, you can't hear it on the phone, even though it's clearly audible to the ears inside the vehicle icon_wink.gif.
However, based on Richard's suggestion, I went back down to the car to specifically examine the plastic pipe in front of the splash guard, and I actually noticed a crack in the intercooler hose that leads to the pipe (see photo).
I hope this is a minor issue and that I can save myself a lot of time and money.
I will get in touch as soon as I receive the hose and have been able to replace it.
You can't really go wrong with Gates, right?
Thank you very much, and I wish you a pleasant evening!
Daniel
 File size:  397.17 KB
 Viewed:  293 times
Translated on 03-09-2026, 16:26.
Post28-06-2023, 8:24    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Thank you for the feedback.
Translated on 03-09-2026, 16:28.
crapSen
2005 Skoda Superb
Post28-06-2023, 9:46    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Hi Rainer, that part won't arrive until today or tomorrow icon_wink.gif.
E30_V8 likes this.
Post13-07-2023, 1:26    Subject: 1.9 TDI AWX Engine Noises Under Load Quote
Hi, quick update: The hose has been replaced, and the noise is gone! Thank you again for your tips / help!
No new posts Expansion Valve Sounds - A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Doku: Engine Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is a roaring sound from the 1Z engine at approximately 15... Diesel Engine Technology
No new posts AAZ only starts under full load?! Diesel Engine Technology
No new posts AGR: Why at Full Load? Diesel Engine Technology
No new posts Performance Drop at Full Load: 3 Error Codes. Diesel Engine Technology
