stolley
11-03-2024, 7:49 Subject: VCDS HEX-USB+CAN: CAN bus not ready |
Good morning, everyone.
This morning I updated VCDS on my computer, and after running the connection test, I'm getting a message that the CAN bus is not ready.
So far, VCDS has always worked without any problems.
Do you have any advice for me?
| Description: |
| File size: |
23.68 KB |
| Viewed: |
561 times |
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
11-03-2024, 9:21 Subject: VCDS HEX-USB+CAN: CAN bus not ready |
Was the interface connected to a vehicle with CAN communication via the OBD2 connector during the interface testing, and was the ignition turned on?
Profile PM WWW Garage |
stolley
11-03-2024, 21:48 Subject: VCDS HEX-USB+CAN: CAN bus not ready |
Hello Rainer,
Thank you for your reply.
The ignition was on, and it was also plugged into the OBD2 port. But I'm not 100% sure if the Polo 9N3 is a vehicle that uses CAN bus technology.
LG
Volker.
11-03-2024, 23:29 Subject: VCDS HEX-USB+CAN: CAN bus not ready |
Your classic car should use the K-Line for diagnostics.
VCDS on classic cars, compatibility
Recognizable by the red stripe, specifically for the Polo 9N model.
stolley
dieselschrauber likes this. |
12-03-2024, 22:02 Subject: VCDS HEX-USB+CAN: CAN bus not ready |
I've now connected VCDS to a newer vehicle again and performed the connection test. This time, the CAN test was also successful!
Now that the configuration is complete, I can also read data from my old device again – which wasn't working before.
But I probably made a mistake somewhere else.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
