1Z MSG connector pinout
Cooger
Karma: +0 / -4   Thank you, like it!
Post27-01-2011, 20:06    Subject: 1Z MSG connector pinout Quote
Evening everyone,
I installed a 1Z 1.9 TDI engine from a Golf into a Caddy 2 SDI 9kv.
"Everything is working fantastically except for 2 errors in the MSG: 'implausible brake pedal signal' occurring sporadically. I've already replaced both brake pedal sensors and adjusted the synchronization, but I still get a flashing glow plug indicator after varying amounts of driving time. It's annoying."
The second issue is the speed signal. I've noticed that the head unit (HU) doesn't display the speed in km/h during driving. As far as I know, it's a purple wire, which I also have from the car's electrical system. However, I don't know which pin on the head unit this wire should be connected to.
"Does anyone have a pinout, preferably with wire colors, for the aforementioned MSG (Message Security Gateway)?"
Post27-01-2011, 21:35    Subject: 1Z MSG connector pinout Quote
You still need to complete it. Install the wiring harness from the TDI engine, including the sensors, and the TDI control module (MSG).
Naturally, the SDI and TDI engines, and consequently their control units and wiring harnesses, are different. You will even find differences for 1Z TDI engines, depending on the platform and equipment.
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
Cooger
Post27-01-2011, 23:38    Subject: 1Z MSG connector pinout Quote
"Of course, I completely rebuilt the entire engine wiring harness, including the control unit. I've already driven 6000 km, but this blinking glow plug indicator light is really annoying."
webster
Avatar-webster
2023 Kia Rio
Post27-01-2011, 23:39    Subject: 1Z MSG connector pinout Quote
You've got a PM.
Post28-01-2011, 22:01    Subject: 1Z MSG connector pinout Quote
The aforementioned MSG has a part number. Without it, you can't determine the pinout. There is no definitive 1Z MSG.
Did you also replace the wiring to the brake light switches? The brake light switches might be different.
The vehicle's control unit (ECU) should already be able to read the km/h value from the transmission's sensor, without the need for the GRA (presumably a specific component or system).
Post28-01-2011, 23:01    Subject: 1Z MSG connector pinout Quote
Without it, you can forget about the pinout.
Herbert, how did you arrive at that statement? To the best of my knowledge, the specifications for all 1Z MSG components from the Golf 3 are identical. While there were several differences between the STG models, even a change from MSA 12 to MSA 15, I'm not aware of any difference in the (external) pinout.
If my memory serves me correctly from a few years ago, you could use part number 021 906 028 BF (MSA15) as an example, or the ending letter C (MSA12, without WFS).
Both part numbers are from my active Golf days, and I'm recalling them from memory. Okay, please don't scold me if I don't remember it correctly anymore.
Greetings.
Guste.
Cooger
Post29-01-2011, 0:06    Subject: 1Z MSG connector pinout Quote
Okay, I'm completely confused now. There are different messages for "1Z"? Can I not use every message from "1Z"? What are the exact differences?
brake light switch, one of which was integrated into the engine wiring harness... the colors are gray... with white/yellow, and the switch should be open to ground, if I understand correctly. The other switch, which controls the rear lights, is red/white and is a closed circuit, but it's old and hasn't been directly measured yet. I'll check that later.
Does the instrument cluster absolutely need the km/h (kilometers per hour) information? And what could be the reason why my instrument cluster shows nothing, but the speedometer works perfectly? km/h = v signal? It should be white and blue on a Golf 3, I also have one like that... Caddy, purple? I also have one of those...
Post29-01-2011, 10:25    Subject: 1Z MSG connector pinout Quote
With the 1Z MSG models, there are already differences, even without considering vehicle-specific variations.
- Engine series with mass airflow sensor, then with mass airflow meter;
- Boost pressure sensor, one inside the MSG (manifold), one external.
- Altimeter, either integrated into the Main System Display (MSG) or located externally;
- Glow plug heater, with or without.
- Water sensor for the diesel filter;
- Immobilizer, with or without;
For the Audi 80 B4 with the 1Z engine, like the one I have, there are at least three different configuration versions (that's how many I have as documentation). According to my repair manual, there are 7 different MSA12 variants for this vehicle type. However, VW/Audi still lists 3 different MSA15 variants as replacements, meaning that not all MSA12 variants can be addressed by simply coding an MSA15 type.
In addition to these, there are also versions used in models like the Golf, Passat, etc.
Cooger
Post29-01-2011, 11:42    Subject: 1Z MSG connector pinout Quote
"Ugh, I'm interrupting your meal, I hope. Can you tell me what that device is?"
VW spare part number: 028906021C.
Manufacturer: Bosch.
Bosch part number: 0281001170/171.
immobilizer, mass airflow sensor, boost pressure regulator, etc.
"Thank you in advance."
Cooger
Post29-01-2011, 13:42    Subject: 1Z MSG connector pinout Quote
I've found out that the mentioned vehicle (likely a car) has the following features: no immobilizer, mass airflow sensor, internal pressure measurement, external altitude sensor.
Cooger
Post29-01-2011, 16:12    Subject: 1Z MSG connector pinout Quote
Okay, I've tested the brake light switch; the yellow/white wire and the ground wire are reaching the control module.
ro/sw on pin 44: no 12V signal, according to the pinout diagram. No connection to the brake light switch that activates the rear lights.
Cooger
Post29-01-2011, 19:28    Subject: 1Z MSG connector pinout Quote
Okay, I think I found it... first of all, many thanks to webster icon_lol.gif.
Okay, so in the Caddy wiring harness, the ro/sw (red/black) wire goes to the ws/yellow (white/yellow) wire. Now, I've located the ro/sw cable from pin 44 in the Golf wiring harness, and I've connected the ws/yellow wire to the ro/sw wire. Now, when the brake is applied, there's 12V on pin 44 from the Golf, which should be it. icon_biggrin.gif
Another puzzle is that the speedometer shows km/h, but the msg (likely a car computer module) doesn't. I've compared the wiring diagrams for both cars, and the ws/bl (white/blue) wires seem to be the same. I've ordered a different msg... we'll see what happens.
thx to everyone, and hopefully finally an end to the blinking check light icon_cool.gif and the f***ing implausible brake light switch signal.
Post30-01-2011, 12:19    Subject: 1Z MSG connector pinout Quote
@CoogerViewing profile: Cooger: I don't want to get too close, but your writing style and, especially, your way of expressing yourself is sometimes completely unacceptable. I ask you to please tone it down a bit! Your posts are sometimes really impossible to read.
Cooger
Post07-02-2011, 17:56    Subject: 1Z MSG connector pinout Quote
TDI-GTI-4Motion
Oh, I'm so sorry.
I'm from the harbor, and my way of speaking is just fine the way it is.
Whoever finds any spelling mistakes is welcome to keep them, and using all uppercase or lowercase letters takes too long for me.
But don't worry, I will try my best to meet your expectations. icon_rolleyes.gif
Post07-02-2011, 22:44    Subject: 1Z MSG connector pinout Quote
Hello.
Even in the harbor, things are rough but friendly. Just please leave out the offensive words. The best way to get a ship's engine running is when the first mate and the engineer have a friendly and professional conversation.
Post31-05-2024, 13:45    Subject: 1Z MSG connector pinout Quote
No new posts Pinout of the MFA (Golf IV) Transmission, Chassis, Body & Interior
No new posts TDI Injector Pump Wiring Diagram Diesel Engine Technology
No new posts OBD2 Pinout: Connector and Wiring Explained Diesel Engine Technology
No new posts Connector assignment: Charging pressure/Charging air temp... Diesel Engine Technology
