GRA Golf VII freischalten/codieren | Posts 16+
Go to page: Previous  1, 2
Wiesel
dieselschrauber likes this.
Post31-05-2024, 9:15    Subject: Quote
Hi.
First of all, thank you to everyone.
Since the GRA (presumably a device or system) can also implement speed limiters, I had set the corresponding bits in the MSTG (likely a configuration or control module) – and it worked.
The corresponding bit in byte 1 of the steering wheel control module could not be set (error message).
The bit for "horn only when ignition is on" in byte 0, on the other hand, could be set without any problems.
We then stopped the process and reset the MSTG coding to its initial state.
This afternoon, I have an appointment at the icon_biggrin.gif, and hopefully, I will get the activation through the code that came with the conversion kit.
I'm excited and will report back.
Micha
Wiesel
Post05-06-2024, 19:04    Subject: Quote
The activation process via the server in WOB went smoothly and was completed in just a few minutes. Price of 57€ seems okay to me.
The addresses 01, 16, and 19 have been modified, with only addresses 01 and 19 having changes in the encoding.
"In 2016, the identical encoding was maintained, but the change resulted in a new WSC (likely that of the selling dealer)."
Unfortunately, I failed to take a snapshot of the customization channels beforehand icon_cry.gif, so I don't know what changes were made in version 16.
Unfortunately, it is no longer possible to trace or verify.
Micha
Post05-06-2024, 19:45    Subject: Quote
Wiesel wrote:
The activation via the server in WOB went smoothly and was completed in a few minutes. Price of 57€ seems okay to me.
Best regards, Micha
Is there a full scan available for the new status?
Wiesel
Post05-06-2024, 21:26    Subject: Quote
Log-WVWZZZAUZEP_____-243411km.txt
 File name:  Log-WVWZZZAUZEP_____-243411km.txt
 File size:  11 KB
 Downloaded:  126 times
Turbinchen likes this.
Post05-06-2024, 21:35    Subject: Quote
For later use.
 File size:  81.48 KB
 Viewed:  249 times
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 6: RCD510 Coding Guide & Instructions Transmission, Chassis, Body & Interior
No new posts How to code US-style features in a Golf V? On-Board Diagnostics (OBD)
No new posts Golf VI: CAYC Engine Coding (or Not) On-Board Diagnostics (OBD)
No new posts Activate comfort blinkers? On-Board Diagnostics (OBD)
