Joined: 04/12/2002 Posts: 18116 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
03-04-2025, 16:47 Subject: |
"Reset" is already the new value.
Profile PM WWW Garage |
Gallo
Joined: 02/18/2025 Posts: 15 Karma: +3 / -0 Location: Gräfenberg 2001 Audi TT Premium Support
Profile PM Garage |
Herbert Profi-Schrauber
dieselschrauber likes this. |
04-04-2025, 9:13 Subject: |
Incorrect.
It is called from inspection. The value is set to 0 km after the inspection, and the value for the time since inspection is also set to 0 days.
You need to know what you're doing, whether you're using the VCDS menu, adjustment channels, or the Audi diagnostic tool.
This is not just a simple switch.
Regarding your vehicle - TDI or gasoline engine, and with the long-life oil change interval?
Was was an Öl gewechselt? If so, was it long-life oil according to VW standard (likely 50700)? Was a service performed? Were any maintenance tasks carried out based on mileage or time intervals?
Without this information, it's impossible to say what should or must be in STG 17 now.
By pressing the button on the instrument panel, you reset the service interval reminder, but the oil change interval is fixed at 15,000 km. The WIV reset switch in the APKs only affects the oil change service and the accumulated oil usage.
A snapshot of the engine control unit (ECU) would show the current values, allowing for a comparison between the desired and actual values.
Gallo
04-04-2025, 15:18 Subject: Reschedule inspection |
After I had saved the values, the display turned off, and I thought, "Finally, it's saved." However, the same message appeared again on the next startup.
Hello Herbert,
Whether.
Oil change performed using long-life oil. During the inspection, the fuel and cabin filters were replaced, the brakes were checked, and fluids were topped up.
I haven't figured out yet why the inspection can't be rescheduled.
Profile PM Garage |
04-04-2025, 19:19 Subject: |
Hi Gallo,
I have a hunch about the persistent service message.
I don't want you to blindly test things, which is why I'm asking again about the STG mapping.
Do you know how it works? VCDS Main Menu > Applications > Create Module Image > Enter Address 17 & Output as CSV file & Select Adaptation.
Gallo
05-04-2025, 13:04 Subject: Reschedule inspection |
Hello Herbert,
Here are the files; I hope I did it correctly.
| Description: |
 Download |
| File name: |
adpmap-17-8W5-920-790-E_WAUZZZFY8K2012271-20250405-1250.CSV |
| File size: |
21.07 KB |
| Downloaded: |
888 times |
Profile PM Garage |
06-04-2025, 18:03 Subject: |
The attached Excel file is an excerpt from the STG diagram and contains the entries for the service intervals. I have added a column with notes.
The entries for the oil change (WIV) are correct, except for the maximum time interval for the LongLife service. There are a few things that surprise me about the entries for inspection (FIX).
Before you change anything, you should...
- Take a picture of the service indicator on the AI unit.
- Take a picture of the service indicator in the information electronics menu (display).
- Copy the file "adplog.csv" from the directory "VCDS/.../Debug".
and of course, post everything here.
The service specifications for your Q5 MJ 2019 are still unclear to me. A service booklet likely no longer exists for that model year, so reliable data can only be found in the "Maintenance" section of the RLF (Richtlinien für die Lebensdauer und Instandhaltung) documentation specific to your model.
I can only assume that it's a TDI model. You don't mention anything about the transmission, but there should also be maintenance requirements for an automatic transmission.
| Description: |
 Download |
| File name: |
Gallos Q5 Serviceanzeige.xlsx |
| File size: |
11.22 KB |
| Downloaded: |
141 times |
Gallo
06-04-2025, 19:33 Subject: Reschedule inspection |
Hey, this can only be from the far north.
Hello Herbert, thank you for your time and patience.
The Q5 is an all-wheel drive vehicle with a 4-cylinder diesel engine producing 190 horsepower and a dual-clutch transmission.
I've adjusted the values for mileage and time several times, but it hasn't made any difference. IDE03349 - I haven't encountered this one yet, with a kilometer reading of 10185.
IDE03350, you're right, it could be the brake fluid service. It was done in 2021 and 2023. I will do it later; I overlooked it.
I'm going to go through the list and modify the values, and I'll see what happens.
The DSG oil was changed every 60,000 km, and the last change was done last year.
Profile PM Garage |
Gallo
Herbert likes this. |
06-04-2025, 20:26 Subject: Reschedule inspection |
Good evening, Herbert,
Following your list, I adjusted all the parameters, and I couldn't believe it at first, but the display went blank. Even after several restarts, it still doesn't work.
I would like to thank you again for your help; it's really great that you took the time and addressed my problem.
Yes, I'm here in Franconia, and I would have liked to invite you for a few beers at our beer garden.
Thank you for the pleasant contact, and have a good evening until next time.
Gallo.
Profile PM Garage |
06-04-2025, 21:41 Subject: |
Thank you for the feedback!
Gallo
08-04-2025, 18:29 Subject: Resetting the Audi Q5 inspection |
Okay, so let me briefly explain again how I postponed the inspection.
Unfortunately, it was not possible to reset the service function, and it also did not respond when the "reset" button was pressed in the circuit breaker panel.
You need to reset and adjust all the parameters in the control panel housing that are related to the inspection, including the mileage and time, as Herbert already mentioned. Otherwise, the control unit will not be reset.
Thank you again for your assistance.
Profile PM Garage |
08-04-2025, 21:51 Subject: |
"But you could definitely donate an automatic scan. It would help the developers at Ross-Tech." Given the wide variety of models, it is simply impossible to offer all functions, such as service reminders, for every vehicle without user input.
Gallo
12-04-2025, 17:27 Subject: Reschedule inspection |
Hello Herbert,
I'm currently away, but I will be doing the car scan in the next few days.
Sure, I can help you with that. Just let me know what you need help with.
Thank you, Gallo.
Profile PM Garage |
12-04-2025, 18:34 Subject: |
It's right there in the link: Autoscan  .
Gallo
13-04-2025, 10:05 Subject: Autoscan Audi Q5 |
Thank you, Herbert. I hope it works out.
| Description: |
 Download |
| File name: |
Log-FO-WH949-WAUZZZFY8K2012271-89249km.txt |
| File size: |
37.01 KB |
| Downloaded: |
141 times |
Profile PM Garage |
