Golf2022
08-04-2022, 7:50 Subject: Retrofitting GRA for VW T-Cross |
Good day.
I'm new here and I already have a question:
We have a VW T-Cross 1.0 from 2021.
MKB: DLAA
GKB: URG
The T-Cross only has a speed limiter, without ACC (Adaptive Cruise Control) or GRA (Gearbox Reconnaissance Algorithm) functionality. PR: 8T9
Is it possible to activate the GRA function using VCDS?
If so, how?
Thank you very much!
Joined: 04/12/2002 Posts: 18097 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
08-04-2022, 7:54 Subject: Retrofitting GRA for VW T-Cross |
Good morning.
Please initiate a full system scan.
Profile PM WWW Garage |
Golf2022
11-04-2022, 13:51 Subject: Car Scan |
Good day.
Attached is the Autoscan report for the T-Cross.
Thank you very much for your help!
| Description: |
 Download |
| File name: |
Log-WVGZZZC1ZMY085316-11650km.txt |
| File size: |
23.99 KB |
| Downloaded: |
980 times |
| Description: |
 Download |
| File name: |
| File size: |
23.99 KB |
| Downloaded: |
891 times |
Golf2022
11-04-2022, 13:57 Subject: Retrofitting GRA for VW T-Cross |
Here's another photo of the steering wheel, hopefully it's helpful...
The keys would be available.
| Description: |
| File size: |
76.99 KB |
| Viewed: |
2301 times |
vag-driver Profi-Schrauber
dieselschrauber and Turbinchen likes this. |
11-04-2022, 16:20 Subject: Retrofitting GRA for VW T-Cross |
I suspect that this coding cannot be performed with VCDS. It probably only works through the central server to ensure that the equipment list is correctly stored in the database, so that the coding isn't reset again during the next visit to the workshop.
Andreas
16-04-2022, 11:19 Subject: Retrofitting GRA for VW T-Cross |
I wouldn't give up  so quickly.
Could you please review the coding options available in the engine control unit (01) and adaptive cruise control (13)?
CUBE
dieselschrauber likes this. |
16-04-2022, 13:13 Subject: Retrofitting GRA for VW T-Cross |
For the car, the GRA (presumably a feature or system) is activated via SwaP, which means it must be unlocked by Volkswagen. Only after this unlocking can you use VCDS for coding. (However, it would be advisable to have Volkswagen perform the coding directly.)
Since the bits are not described here, I'll write it like this:
In MSG byte 5.
Bit 4 enabled = GRA - PR-8T2/8T6.
Bit 6 activated = Adaptive GRA with ACC - PR-8T5.
Bit 5 and 6 activated = Adaptive GRA with ACC and Front Assist (PR-8T3/8T8)
Here's the translation:
"For example, if only GRA were used for the new encoding in the MSG, it would be..."
0125001223240D080000000000000000000000000000000
In the STG 19 module, the APK "SFT271921-MAS06614-Control unit for multifunction steering wheel variant" should be set to GRA-High.
CUBE
dieselschrauber and brezelmann01 likes this. |
10-07-2022, 12:45 Subject: Retrofitting GRA for VW T-Cross |
I just realized I misspelled something.
Byte 5, bit 4 would be the AHK (Application Hook), but the encoding was still correct.
Here is the correction:
In MSG byte 5.
Bit 5 activated = GRA - PR-8T2/8T6.
sharanwolf
Joined: 03/14/2018 Posts: 1 Karma: +0 / -0 Location: Schorndorf
02-04-2023, 12:29 Subject: Activate ACC retroactively |
Hello Cube,
Thank you for the information.
I have a T-Cross here that came with Front Assist from the factory.
So, only the speed limiter is activated.
It has the MFL pro installed.
Unfortunately, all the bits in the MSG/brake control module are undocumented.
I entered the value "24" for you into the MSG. As a result, the limiter symbol disappeared from the MFA, and the ACC symbol appeared, but there are errors in the brake control module and in module 13.
What else do I need to recode in these two devices?
I've now added a scan of the previous page.
Does anyone know the settings in the brake control unit and the "13er" (likely referring to a specific module or system)?
Greetings.
| Description: |
 Download |
| File name: |
Log-xxx-15849km.txt |
| File size: |
10.76 KB |
| Downloaded: |
414 times |
CUBE
sharanwolf likes this. |
02-04-2023, 20:49 Subject: Retrofitting GRA for VW T-Cross |
Hi, you need to enter "64" in the MSG field on your end. The 24 was the example without ACC for the above.
0111001223640D080000000000000000000000000000000
ADpoppe
09-05-2025, 12:30 Subject: Upgrade GRA |
Hi... I always get errors in the MSG, no matter which coding I choose.
Can anyone help?
Thank you.
| Description: |
 Download |
| File name: |
Log-HP PE 624-WVGZZZC1ZMY002955-65209km.txt |
| File size: |
28.77 KB |
| Downloaded: |
163 times |
09-05-2025, 18:50 Subject: Retrofitting GRA for VW T-Cross |
What does LCode say?
ADpoppe
11-05-2025, 13:47 Subject: Means? |
Is there anything else you need? It's sometimes offered, supposedly without requiring any hardware.
21-05-2025, 11:30 Subject: Retrofitting GRA for VW T-Cross |
dieselschrauber wrote: | | What does LCode say? |
Nash
Joined: 06/13/2006 Posts: 50 Karma: +0 / -0 Location: 92637 Weiden 1997 Volkswagen Passat Premium Support
21-05-2025, 16:48 Subject: GRA Audi Q2 |
I'm just chiming in here. This week, I retrofitted a cruise control system to my Q2, which is a model from December 2021. The SVM codes were provided by the seller.
My local Audi dealer wasn't thrilled to just be allowed to/required to make the adjustment. That means he rejected it outright.
Audi Q2.
MKB: DNNA
PR: 8T9
The vehicle only has a speed limiter.
The LOG is attached.
Thank you very much.
| Description: |
 Download |
| File name: |
Log-WAUZZZGA1NA015489-40548km-Baier.txt |
| File size: |
21.17 KB |
| Downloaded: |
211 times |
AFN mit aktuell 546.465km auf der Uhr
Profile PM Email Garage |
