Retrofit Passat 3BG Electric Folding Mirrors
andi_j
Post25-07-2026, 8:29    Subject: Retrofit Passat 3BG Electric Folding Mirrors Quote
Hello everyone,
Hope you're all doing well!
I didn't find anything using the search function, so I thought I would start a thread about an old car. icon_biggrin.gif
Okay, I have a Passat sedan (model 3BG) from 2003. It originally didn't have power windows in the rear, but I want to add them.
"We've completely rebuilt everything, extended the wiring harness (removed all the original components from a scrapped car and installed them here), replaced the front left and right door control modules, and I also have a central locking system with part number xxx799B."
The problem now is that when I install the TSGs (window regulators), the other existing TSG from vo.li. isn't recognized as the one currently installed, and similarly, the KSG (control unit) isn't recognized when I replace it. And even if I code the KSGs for a "4-door car with 4 electric windows," I still end up with a cascade of errors in the fault memory.
Error:
CAN bus corporation.
and all those TSGs (technical support groups) with no communication.
I measured and checked the cables, and there are no breaks or bad connections, so everything seems to be fine.
Can someone possibly help me here?
Best regards from Carinthia!
Translated on 25-07-2026, 8:33.
Post25-07-2026, 10:53    Subject: Car Scan: Diagnostics & Repair Guide Quote
Autoscan?
Translated on 25-07-2026, 10:53.
andi_j
dieselschrauber likes this.
Post25-07-2026, 11:43    Subject: Retrofit Passat 3BG Electric Folding Mirrors Quote
I don't have it on hand right now, but I actually just put everything back together.
What I was able to find out is;
I have the "1C0 959 799 A" KSG (allegedly capable of handling 4 eFH), the "1C1 959 801/802" front headlights, and apparently need the "1C0 959 811/812" headlights for the rear.
The rear door control modules I received are from a 3B Passat.
It seems there's a mismatch with the bus system, which is causing the KSG (likely referring to a specific system or component) to fail.
Translated on 25-07-2026, 11:44.
Post25-07-2026, 11:55    Subject: Retrofit Passat 3BG Electric Folding Mirrors Quote
Thank you for the feedback, I'm excited icon_biggrin.gif.
Translated on 25-07-2026, 11:55.
andi_j
Post25-07-2026, 15:43    Subject: Retrofit Passat 3BG Electric Folding Mirrors Quote
Yes, me too. Now I need to figure out where to get some... XX.
Translated on 25-07-2026, 15:44.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts GRA installation on the Passat 35i TDI 1Z: Steering wheel... Diesel Engine Technology
No new posts Retrofit MFA on a Passat 35i TDI 1Z Special Model Court Diesel Engine Technology
No new posts Aero Wiper Blades: Retrofit for VW Passat 98 Transmission, Chassis, Body & Interior
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
