Erikmar
12-08-2026, 11:49 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
"Hi, I have a VW T4 Caravelle from 2002 with the AJT 2.5 TDI engine. My problem is that the car was heavily smoking black during driving and then stalled. Since then, it hasn't started properly. I've been able to pinpoint the source of the problem to the mass airflow sensor. Here's my issue: I can see the target value in function block 02 and observe how it changes when I adjust things. In function block 019, which shows the initial values, I should have 1 volt and 5 volts, but instead, I only get 1 volt on both readings. VCDS reported an error code: "mass airflow sensor - lower limit."
Can someone help me with this?
Translated on 12-08-2026, 11:50.
Joined: 04/12/2002 Posts: 18061 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
12-08-2026, 12:04 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Translating... |
[Translating...] Autoscan?
Profile PM WWW Garage |
Erikmar
12-08-2026, 12:27 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
I'll send it over later.
Translated on 12-08-2026, 12:27.
Erikmar
12-08-2026, 12:58 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
It's not showing me any errors right now.
| Description: |
| File size: |
5.98 MB |
| Viewed: |
58 times |
| Description: |
| File size: |
3.52 KB |
| Viewed: |
57 times |
Translated on 12-08-2026, 12:59.
Erikmar
12-08-2026, 15:05 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay, all the measurements are within acceptable limits except between values of 3 and 5, or 6 and 7, where there is no resistance detected.
| Description: |
| File size: |
5.91 MB |
| Viewed: |
43 times |
| Description: |
| File size: |
6.4 MB |
| Viewed: |
43 times |
Translated on 12-08-2026, 15:06.
Erikmar
12-08-2026, 15:19 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay, yes, that's right. And before I forget, the anchor switch – specifically, the quantity selector – isn't working at all; it doesn't engage or disengage when you turn the ignition on.
Translated on 12-08-2026, 15:20.
Herbert Profi-Schrauber
12-08-2026, 15:21 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
"Someone is objecting to the automatic scanning."
Does "no resistance" mean a measured value of R = infinity or R = 0?
"hg"
Translated on 12-08-2026, 15:22.
Erikmar
12-08-2026, 15:23 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
In my case, "no resistance" means an infinitely high resistance.
I'm sorry, I could have described that better.
Translated on 12-08-2026, 15:23.
12-08-2026, 15:34 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay.
Translated on 12-08-2026, 15:34.
Erikmar
12-08-2026, 15:36 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay, and why doesn't the slider perform a reference run when starting? And how are the values "1,... V" obtained in the VB 19?
Translated on 12-08-2026, 15:36.
12-08-2026, 16:08 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
You're reading at least 1 MΩ up there, right?
Translated on 12-08-2026, 16:09.
Erikmar
12-08-2026, 16:11 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay, that seems right, but under the measurement block "019," there's a "start" and I think a "stop" function, or something like that. The voltages have always been around 0.7V and a good 4V, but now both are showing the same value, which is about 1V.
Translated on 12-08-2026, 16:12.
12-08-2026, 16:53 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Okay, here's the translation:
"Now, please provide the car scan."
Translated on 12-08-2026, 16:53.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +642 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
12-08-2026, 17:46 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Suspected cable break in the area of the starter motor.
Translated on 12-08-2026, 17:46.
Profile PM Garage |
Erikmar
12-08-2026, 18:47 Subject: T4 AJT ESP Issues: Troubleshooting & Solutions |
Hi.
Okay, so the explanation for why the FB 019 values were at 1V: There are two hidden fuses inside the unit, above the relays. One of them was blown. Since then, it's been working fine.
Translated on 12-08-2026, 18:47.
