Skoda Octavia: Reset Oil Service Light
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
nutzer-432
Post12-09-2026, 13:10    Subject: Skoda Octavia: Reset Oil Service Light Quote
Hello community,
On a Skoda Octavia NX, manufactured in 2020, using VCDS version 26.3.0.0, I found the following entries related to oil service under control module 17, adaptation channel 10:
Reset oil service, oil quality, oil contamination, oil thermal load, distance since last oil service, time since last oil service, and minimum and maximum distance to next oil service, as well as minimum and maximum time to next oil service.
The vehicle is displaying an oil service reminder. To reset it, I set the "time since last oil service" and "distance since last oil service" values to zero. This reset was accepted.
The oil service warning is currently active. The reset option is also available in the selection menu, but any attempt to change the setting is not being accepted.
The entries "Russeintrag" and "therm. Belastung" cannot be changed. The other oil-related entries listed above do not appear to be problematic.
How can the oil service reminder be reset?
Translated on 13-09-2026, 9:14.
Post13-09-2026, 9:11    Subject: Skoda Octavia: Reset Oil Service Light Quote
Autoscan?
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 13-09-2026, 9:13.
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 3 engine noise, 85 kW, 1600cc TDI Diesel Engine Technology
No new posts BLR 2.0 FSI Skoda Octavia: Replace timing chain of camshaft Gasoline Engine Technology
No new posts Skoda Octavia Rear Window Heater: Broken Connector Transmission, Chassis, Body & Interior
No new posts Login Code for Comfort Control Unit in Skoda Octavia On-Board Diagnostics (OBD)
