nutzer-432
12-09-2026, 12:10 Subject: Skoda Octavia: Reset Oil Service Light |
Hello community,
On a Skoda Octavia NX, manufactured in 2020, using VCDS version 26.3.0.0, I found the following entries related to oil service under control module 17, adaptation channel 10:
Reset oil service, oil quality, oil contamination, oil thermal load, distance since last oil service, time since last oil service, and minimum and maximum distance to next oil service, as well as minimum and maximum time to next oil service.
The vehicle is displaying an oil service reminder. To reset it, I set the "time since last oil service" and "distance since last oil service" values to zero. This reset was accepted.
The oil service warning is currently active. The reset option is also available in the selection menu, but any attempt to change the setting is not being accepted.
The entries "Russeintrag" and "therm. Belastung" cannot be changed. The other oil-related entries listed above do not appear to be problematic.
How can the oil service reminder be reset?
Translated on 13-09-2026, 8:14.
Joined: 04/12/2002 Posts: 18134 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-09-2026, 8:11 Subject: Skoda Octavia: Reset Oil Service Light |
Autoscan?
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 13-09-2026, 8:13.
Profile PM WWW Garage |
nutzer-432
14-09-2026, 10:50 Subject: Skoda Octavia: Reset Oil Service Light |
Hello admin,
Thank you for your feedback. Please find the LOG file from the full auto scan attached.
| Description: |
 Download |
| File name: |
Log-Oktavia-V--TMBJG7NX3LY024216-58497km-12-09-2026.txt |
| File size: |
25.52 KB |
| Downloaded: |
160 times |
Translated on 14-09-2026, 11:01.
Herbert Profi-Schrauber
dieselschrauber likes this. |
14-09-2026, 13:22 Subject: Skoda Octavia: Reset Oil Service Light |
First, charge the battery. Quote: | | End--(Duration: 02:38, Battery voltage start/end: 11.6V/11.6V. VIgn 11.7V) | is already low. Maybe then the communication will work.
Translated on 14-09-2026, 13:24.
nutzer-432
17-09-2026, 13:37 Subject: Skoda Octavia: Reset Oil Service Light |
Hello Herbert,
Thank you for the U-Batt tip. The reset is now working. I'm observing a drop in U-Batt voltage of several hundred millivolts over just a few minutes, solely through diagnostics (for a 2-year-old battery). If anyone knows the undervoltage threshold for this process, please share it here.
Translated on 17-09-2026, 13:37.
17-09-2026, 14:39 Subject: Skoda Octavia: Reset Oil Service Light |
Hi there.
12 volts would already be low in a resting state, whether it's an AGM or EFB battery.
Translated on 17-09-2026, 14:39.
