Audi 80 Avant Wheel Alignment - Caster Adjustment
640Hatza
Post14-10-2026, 0:56    Subject: Audi 80 Avant Wheel Alignment - Caster Adjustment Quote
Hello everyone,
I recently took my Audi 80 Avant 1.9 TDI 1Z to a workshop for a wheel alignment.
The reason was that I had the two axles overhauled two years ago, but they were only roughly adjusted and installed.
I had adjusted the rear axle according to the manufacturer's specifications.
Furthermore, I installed a KW V1 coilover suspension system and adjusted it to a ride height of 320mm.
For the measurement, I drove with new tires icon_smile.gif.
What do you think about the set values?
Following the values, the collapse was not touched icon_sad.gif.
Can this be adjusted on a wheel alignment machine without the special tool?
Almost 1.5 degrees is quite a bit, isn't it?
Thank you in advance for your feedback.
 File size:  278.92 KB
 Viewed:  4 times
Translated on 14-10-2026, 0:58.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Audi A6 4F Avant Kombiinstrument, VAG-COM. On-Board Diagnostics (OBD)
No new posts Adjusting Xenon Headlights on an Audi A4 Avant On-Board Diagnostics (OBD)
No new posts Audi 80 Avant 1Z: Dynamic Injection Timing Type? Diesel Engine Technology
