Audi C4 AAT: Idle unstable, stalling sometimes
rudtan
Post18-10-2026, 16:00    Subject: Audi C4 AAT: Idle unstable, stalling sometimes Quote
Hello everyone,
I recently bought an Audi A6 2.5 TDI, model year 1995, with the AAT engine.
"For about two weeks now, the idle speed has been acting up. It doesn't happen all the time, but when it does, it's quite noticeable. Initially, there are slight fluctuations, sometimes leading to the engine stalling. If I give it a strong burst of gas while idling, it usually works for a while, but the problem soon returns. Then there are times when everything seems fine. Any ideas what might be causing this?"
Greetings, Rudi.
Translated on 19-10-2026, 17:16.
Back to top Profile PM Email
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
dieselschrauber likes this.
Post19-10-2026, 0:07    Subject: Audi C4 AAT: Idle unstable, stalling sometimes Quote
My first thought would be that there's air in the fuel.
Furthermore, there are crankshaft position sensors or needle lift sensors, but those should be stored in the error memory.
Translated on 19-10-2026, 0:08.
rudtan
Post19-10-2026, 12:28    Subject: Audi C4 AAT: Idle unstable, stalling sometimes Quote
Thank you for the reply. I got an adapter for the reading device today.
There are 2 errors embedded.
00522 Coolant temperature sensor.
00513 Engine speed sensor.
Is point number 2 your assumption?
Best regards, Rudi.
Translated on 19-10-2026, 12:29.
Tagessuppe
Post19-10-2026, 12:32    Subject: Audi C4 AAT: Idle unstable, stalling sometimes Quote
Okay. That's the crankshaft position sensor, which also serves as the speed sensor.
That's probably it.
Translated on 19-10-2026, 12:33.
rudtan
Post19-10-2026, 12:36    Subject: Audi C4 AAT: Idle unstable, stalling sometimes Quote
Thank you for the quick response. I will get one and post the results.
Have a nice day!
Translated on 19-10-2026, 12:37.
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts 1.9 TDI (AWX) Audi A4 runs roughly when idling. Diesel Engine Technology
No new posts A3 1.6 Engine Failure: Causes & Solutions On-Board Diagnostics (OBD)
No new posts Absterben nach 5 Minuten Lauf bei Kälte! Diesel Engine Technology
No new posts A4 B6 2.5 TDI: Running Rough - Troubleshooting Diesel Engine Technology
