Lothar Guest
11-03-2004, 13:52 Subject: Seal Tandem Pump: How To & Best Practices |
The tandem pump (pump-injector) in my Golf is leaking. Before I take it apart to have it repaired, I would like to understand exactly how it works.
I would appreciate any relevant information, whether it be drawings, explanations of functionality, specifications, or potential sources of error.
Has anyone else experienced this problem?
Lothar.
Translated on 07-09-2026, 16:05.
PowerSound3L Guest
11-03-2004, 15:41 Subject: Seal Tandem Pump: How To & Best Practices |
hi,
It seems this problem occurs more often.
Meanwhile, there is a revised version with different seals.
'However, there apparently isn't a replacement seal available, so the entire pump needs to be replaced.'
That's all I know about it.
greetings
Translated on 07-09-2026, 16:06.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
13-09-2004, 22:00 Subject: Seal Tandem Pump: How To & Best Practices |
hi!
Unfortunately, my injection pump is also getting wet, and the diesel is spreading as a very thin, creeping, and sticky film all over the engine  . As far as I can tell, it is definitely diesel and not engine oil. Therefore, I would like to revisit Lothar's question and ask if anyone has already attempted to disassemble it. I am familiar with the operation of the pump from the SSP 209, but I have unfortunately never seen an opened pump.
It would be annoying if half of the contents spilled out when I open it... Does anyone have any photos or reviews?
Unfortunately, besides the seals between the fuel injection pump and the pump body, nothing else is available. Is it possible to permanently seal the pump itself using sealant? Which sealant would be best? It absolutely must be fuel-resistant.
"Thank you!"
Dirk. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 07-09-2026, 16:07.
Marco1001
dieselschrauber likes this. |
23-02-2023, 20:39 Subject: Seal Tandem Pump: How To & Best Practices |
Sealing from the outside is not a problem! Simply remove the yellow zinc-plated lid.
Wipe off any diesel and make sure everything is completely clean and free of grease (you can even reuse the old O-ring, just remove it and make sure everything is clean). Then, apply a thin layer of Reinzosil sealant all around the circumference, reattach the cover, and you're done!
No parts will fall out if you work carefully.
Best regards to everyone.
Translated on 07-09-2026, 16:09.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
dieselschrauber and E30_V8 likes this. |
24-02-2023, 17:59 Subject: Seal Tandem Pump: How To & Best Practices |
Quote: | No parts fall out when working carefully.
Don't use it to fill the gap, especially if you're not experienced with sealants. Silicone has no place here; there are sealant kits specifically designed for this purpose. LG, Onkel BM
Translated on 07-09-2026, 16:10.
Johnson
29-11-2026, 16:13 Subject: Seal Tandem Pump: How To & Best Practices |
Hi everyone, I'm bringing this topic up again for a specific reason. I'm currently working on a used 1.9 TDI PD (AXR) engine from a friend, and I need to re-prime the tandem pump.
Die Pumpe selbst ist mit dem bekannten Dichtsatz mittlerweile schon wieder dicht, allerdings (musste ja was sein) schwitzt einer der Leitungsanschlüsse an der Hohlschraube doch noch leicht nach. Die Dichtfläche am Alugehäuse der Pumpe hat über die Jahre n paar feine Riefen abbekommen, und mit normalen Kupfer- oder Aludichtringen bekomm ich das nicht sauber dicht, ohne die Schraube im weichen Alugehäuse unangenehm fest anknallen zu müssen. Normaler Gummi-O-Ring drückt sich mangels Einstichnut beim Anziehen natürlich sofort seitlich weg.
"Has anyone of you used metal-rubber composite seals from the hydraulic sector on TDI (tandem pump, fuel filter, or oil lines)? These seals provide a tight seal even with low torque and don't tend to migrate. I'm particularly interested in knowing whether NBR or FKM/Viton have proven to be durable against diesel and engine oil in your experiences." Alles hat ein Ende, nur die Wurst hat 2
Translated on 29-11-2026, 16:16.
