Air conditioner leaking??
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
SonGoko
Post18-06-2002, 13:04    Subject: Air conditioner leaking?? Quote
Hello, I have a question about the air conditioning system in my Passat with a 90 horsepower engine, manufactured in 1999. Since I had my car serviced, I've noticed a small puddle of water under my car. I suspect it's related to the air conditioning system. The dealer told me it's condensation, but I'm not sure if I had water under the car before. Is this normal, or should I go back to my dealer?
Post18-06-2002, 13:21    Subject: Air conditioner leaking?? Quote
Hello, the humidity condenses on the cold parts of the air conditioner, so a small puddle of water is perfectly normal.
If the air conditioner has a leak, it will automatically shut off (due to the low internal pressure).
SonGoko
Post18-06-2002, 13:33    Subject: Air conditioner leaking?? Quote
Mtw13ve
Post29-06-2002, 18:32    Subject: Air conditioner leaking?? Quote
I thought the same thing at first... it's the condensate drain hose. Clear that and replace the pollen filter! You'll find the hose on the left side of the passenger seat.
No new posts Air conditioner smells bad General Tips
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts KGE leckt Diesel Engine Technology
No new posts A6 C4 AAT/AEL Einspritzpumpe leckt Diesel Engine Technology
No new posts Automatikgetriebe leckt --> 2000 EUR Aufwand ? Transmission, Chassis, Body & Interior
No new posts Windshield washer pump leaking: Tips for sealing it? Transmission, Chassis, Body & Interior
