Gremlin Guest
02-03-2004, 9:34 Subject: |
Take a look at this:
www.tt-eifel.de/index.htm?technik/serviceanzeige/serviceintervallanzeige.html
CU Gremlin.
Julian Guest
02-03-2004, 9:43 Subject: |
Interesting, but it's only partially helpful. But at least it is now clarified that faking  is not possible.
Gremlin Guest
02-03-2004, 11:24 Subject: |
Of course, that's possible.
'Someone, somewhere, has to sit down and capture the desired state using an oscilloscope, and then have an AVR microcontroller reproduce it.'
ready
CU Gremlin.
Bertil Profi-Schrauber
02-03-2004, 12:59 Subject: |
Gremlin wrote: | double posting (can't delete it, why?)
... because you don't have the permission to do that in this forum (neither do I  ). Ask Rainer. Gruß Bertil
Julian Guest
02-03-2004, 15:38 Subject: |
Hm, as a poor little pig, I wouldn't describe Gremlin as someone with great expertise.....
But seriously... You would definitely be the only one here who could do something like that... There are plenty of people who would be interested!
z-man Guest
02-03-2004, 16:44 Subject: |
Hey, thanks to everyone for the quick help! What's surprising is that it doesn't always show the error on the display! Only occasionally, and only when starting up! After that, I can drive 1000 km without receiving any warnings!
Best regards.
micha
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
02-03-2004, 18:43 Subject: |
Bertil wrote: | Gremlin wrote: | double posting (can't delete it, why?)
... because you don't have the permission to do that in this forum (neither do I ). Ask Rainer. |
But now it works; I simply forgot about it when I created the new forum.
Profile PM WWW Garage |
Gremlin Guest
02-03-2004, 19:26 Subject: |
But seriously... You would definitely be the only one here who could do something like that... There are plenty of people who would buy it!
Well... I can try to measure that sometime, depending on the weather and my mood. But even then, it won't be enough for AVR programming.
CU Gremlin.
mersente Guest
02-03-2004, 23:11 Subject: |
Here's the translation:
'Sensors are available individually, so what if you simply installed one in a container filled with oil, outside of the oil pan? Then the oil level and oil quality would always be good, which might be cheaper than a fake sensor.'
02-03-2004, 23:22 Subject: |
Cool idea
Gremlin Guest
03-03-2004, 6:05 Subject: |
Sensors are available individually, so what if you simply installed one in a container with oil outside of the oil pan? Then the oil level and oil quality would always be good, which might be cheaper than a fake one.
Well... something like an AVR microcontroller costs around 3 to 5 euros .
CU Gremlin.
mersente Guest
03-03-2004, 23:17 Subject: |
@Gremlin:D ann, could you please send over the instructions? I think some people would be interested.
