XENON...2 Bulbs, 2 Days, One Headlight (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Polarlarry
Post07-04-2004, 8:22    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Hi there,
I'm currently icon_twisted.gif dealing with my headlights (Xenon). Yesterday, the left headlight was dark. It was basically 'game over.' Well, it's understandable after 150,000 km with constant lighting (day and night).
So, you can get it replaced (for 175 euros icon_cry.gif) and be happy again.
The next morning: Get in the car and go. After 5 kilometers... 'Game over' for the front left tire! icon_twisted.gif Again!
So, back to the workshop again.
Does anyone know of a similar phenomenon?
Can the light bulb be tested?
Translated on 10-07-2026, 18:46.
Holger247
Post07-04-2004, 8:37    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Perhaps it's an installation error made by the workshop?
Or is there a fault in the control system (ballast)?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 10-07-2026, 18:47.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post07-04-2004, 19:16    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Remove the pear and check if it's still intact.
If the glass has a slightly brownish tint, it's okay.
Wenn es Grau bis Schwarz ist . DEFECTIVE.
The ballasts and the bulbs are balanced in terms of how likely they are to break down. icon_eek.gif
B.Eng (FH) u. KFZ Meister
Translated on 10-07-2026, 18:48.
Polarlarry
Post08-04-2004, 12:56    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Also, ich war dann in der Werkstatt....Lampe war zum Glück noch i.O. icon_biggrin.gif
I didn't realize that the headlights are insured separately (left and right).
Anyway... thanks for your help.
By the way, these ballast devices cost around 10 euros to manufacture (I used to work for a supplier company).
Post08-04-2004, 14:23    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Okay, so you should have stocked up on some of those earlier... VW really wants to see a good supply available. By the way, if you're patient and have a lot of willpower, the "DS" (or whatever they're actually called) xenon bulbs are universal and can be found quite cheaply online. If the ballast is defective, you can usually identify that beforehand with a diagnostic check!
Translated on 10-07-2026, 18:49.
Polarlarry
Octavia_4x4 likes this.
Post09-04-2004, 18:26    Subject: XENON...2 Bulbs, 2 Days, One Headlight Quote
Guys... it gets even worse.
I had some free time today and decided to open up my headlight assembly.
After two more fuses blew last night, I...
fed up.
Okay:
Fuse removed, measuring against ground: 0 ohms for the left headlight, infinite ohms for the right headlight.
Okay, so disconnect the plug from the entire headlight assembly... Resistance is infinite... The cable is fine.
Then I'll take a peek inside the open headlight from behind... AHA!
A delicate yellow cable cheerfully rubs against a metal tab inside the headlight.
Awesome construction icon_evil.gif.
Hella deserves some praise for that.
I insulated the cable and added some padding (foam) for protection.
Everything assembled, but the resistance is still infinite... great.
Meine Vermutung ist nun, das die Fuzzies in der Werkstatt eine vollkommen intakte Birne in die Tonne getreten haben und ich 180 Euro bezahlt habe für eine neue...die ich nicht brauchte.... icon_evil.gif
If you don't do everything yourself... grrrrrr...
But perhaps it will help you, as the construction should be similar in most A6 models.
Because it is still physically very unlikely for a shielded gas arc to break down. Also, the power supplies are actually quite robust.
When replacing bulbs or ballasts, you inevitably touch some wires (the short circuit disappears)... and magically, everything is working again.
Translated on 10-07-2026, 18:51.
Ratings - XENON...2 Bulbs, 2 Days, One Headlight
Average rating: 4.00 - worst rating: 4 - best rating: 4 - number of ratings: 2 - View ratings
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about foggy headlights and odors inside Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Capital Engine Damage. AFB, 3 years + 3 days with 125,000 km Diesel Engine Technology
No new posts Xenon Scheinwerfer On-Board Diagnostics (OBD)
No new posts Headlight Chip Damage - No Inspection Transmission, Chassis, Body & Interior
No new posts Andere Scheinwerfer für den Golf IV Transmission, Chassis, Body & Interior
