Tribune.Inc Guest
13-04-2004, 16:55 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Hi everyone,
I couldn't find an answer to my question even after using the search function, and here's the problem:
I have an AUDI 80 B4 1.9 TDI (manufactured in May 1993) and a speedometer (with a mileage indicator) that has been removed and apparently completely disassembled.
Result: The speedometer is not working, and when it does, it only works sporadically, very rarely. Sometimes, the speedometer needle even stops completely, but this can usually be fixed with a gentle tap. Also, the lighting is not working everywhere, or it is working poorly.
I'm now planning to replace the entire instrument cluster. Since I can't find a well-maintained instrument cluster from a TDI, I wanted to ask if it would cause any major problems to install one from a gasoline-powered car, especially regarding the fuel gauge and tachometer. The speedometer should be fine since it only goes up to 220 km/h!
and please don't scold me if I missed something in the search function!!!
Please help me with your tips and suggestions!
Thank you in advance!
Best regards, Mike
Translated on 31-10-2026, 19:19.
13-04-2004, 18:08 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Regarding the Volkswagen Golf 3, I can tell you that all the gasoline engine models have speedometers with different mileage readings (impulse counts), so the speed indication will not be accurate.
As far as I know, TDI diesel engine control modules (ECMs) are not compatible with gasoline engine control modules.
m; Transparency, Teamwork
Translated on 31-10-2026, 19:21.
Profile PM Garage |
WarLord Guest
13-04-2004, 19:24 Subject: TDI to Gasoline Conversion: Cost & Benefits |
It is often claimed, but it is not true. The speed signals come from the engine control unit (MSG) and not directly from the Hall sensor or similar components (at least, this is the case with the Passat 35i B4). Therefore, a gasoline engine speedometer should also fit into a TDI engine (an American has installed a VR6 speedometer into a TDI, and it worked).
Best regards, WarLord.
Translated on 31-10-2026, 19:22.
Jan03 Blaumann
Joined: 08/24/2003 Posts: 142 Karma: +6 / -0 Location: Dänemark 2010 Volkswagen Polo Free account, no CAN development support
13-04-2004, 19:44 Subject: TDI to Gasoline Conversion: Cost & Benefits |
I also had a gasoline speedometer in my TDI, and I believe that both of them worked, so the tachometer and the speedometer. I definitely drove around with it for a few days, and I didn't notice anything unusual, except that the preheating light wasn't there.
I can try it again next weekend if there's still interest.
/Jan
G3, 1Z, 94
Translated on 31-10-2026, 19:23.
Profile PM Garage |
Jan03 Blaumann
13-04-2004, 19:46 Subject: TDI to Gasoline Conversion: Cost & Benefits |
...Of course, assuming that Tribune.Inc is interested. I'm already generating the interest  .
/Jan
Translated on 31-10-2026, 19:24.
Profile PM Garage |
WarLord Guest
13-04-2004, 20:07 Subject: TDI to Gasoline Conversion: Cost & Benefits |
So, has this tiresome issue finally been resolved?
Tribune.Inc Guest
13-04-2004, 20:14 Subject: TDI to Gasoline Conversion: Cost & Benefits |
I also had a gasoline speedometer in my TDI, and I believe that both of them worked, so the tachometer and the speed display. I definitely drove around with it for a few days, and I didn't notice anything unusual, except that the glow plug light was missing.
I can try it again next weekend if there's interest.
/Jan
G3, 1Z, 94
Hi, thanks for your help, and I'd like to know if everything fits! Also, do I need to pay attention to the manufacturing year, or does it not matter regarding the connectors?
Best regards, Mike!!
P.S.: @WarLord... yes, I think that troublesome issue has been resolved.
Translated on 31-10-2026, 19:25.
WarLord Guest
13-04-2004, 20:22 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Is that a fully electronic speedometer, or does it still have a mechanical linkage?
Translated on 31-10-2026, 19:26.
Tribune.Inc Guest
14-04-2004, 9:20 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Is that a fully electronic speedometer, or still one with a cable?
Greetings, WarLord.
It is fully electronic!!
WarLord Guest
14-04-2004, 9:50 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Then there shouldn't be anything preventing the exchange from happening.
Translated on 31-10-2026, 19:27.
Tribune.Inc Guest
14-04-2004, 16:47 Subject: TDI to Gasoline Conversion: Cost & Benefits |
Then there shouldn't be anything standing in the way of the exchange.
Greetings, WarLord.
Thank you for your help!!!!!
Best regards, Mike.
Jan03 Blaumann
18-04-2004, 17:54 Subject: TDI to Gasoline Conversion: Cost & Benefits |
@ Tribune.Inc
I've tried it again, as promised.
Conclusion: WORKS PERFECTLY
The speedometer and tachometer are both working correctly. The fuel and temperature gauges also seem to be accurate, but the oil pressure light is not shining as brightly, although it is still functioning.
So, no talk of different heart rates for different distances or anything like that!
(One was from a 1Z engine and one was from an ABS system (1.8L, 90HP), both were fully electronic.)
Jan.
Translated on 31-10-2026, 19:28.
Profile PM Garage |
