TDI VW Golf 3: Smoking Exhaust & Overheating Issues
flo__911
Post08-05-2004, 21:16    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
I'm having the following problem. My Golf 3 is emitting black smoke from the exhaust and isn't running properly. It struggles to accelerate in first gear, pulling slowly. From second gear onwards, the performance is moderate. I recently replaced the radiator with a thermostat switch, and since then, it hasn't been working correctly. After driving for a short distance, coolant sprays out excessively from the coolant reservoir cap (when you open it).
I only drove for a very short distance, about 100 meters, without the cooler running.
Can you tell me what might be causing this?
Best regards.
Flo.
Translated on 22-08-2026, 6:40.
Manuel Thomas
Post08-05-2004, 23:20    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
The engine is overheating and producing black smoke!
Faulty nozzles!
Manuel.
Translated on 22-08-2026, 6:42.
Julian
Post09-05-2004, 10:21    Subject: VW Golf 3 TDI: Smoking Exhaust & Overheating? Quote
Counter-question: Do you even know what you did?
Manuel Thomas
Post09-05-2004, 10:25    Subject: VW Golf 3 TDI: Smoking Exhaust & Overheating? Quote
Counter question: Do you even know what you did there?
Nothing really bad! Opening the expansion tank was much worse!
Manuel.
Translated on 22-08-2026, 6:43.
Marco
Post09-05-2004, 11:03    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
Hi Flo,
The error likely only started occurring after the radiator was replaced; at least, that's how it seems.
Are you sure everything is connected correctly? Please double-check it.
Are both cooling circuits being addressed? After a drive, all the radiator hoses should be roughly the same temperature. If this is not the case, the control valve will malfunction. Did you also properly bleed the cooling circuit? The engine code (MKB) would also be helpful.
Translated on 22-08-2026, 6:45.
D.
Post09-05-2004, 16:57    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
@ Manuel Thomas
My coolant temperature has been significantly lower than usual since last year (now only around 75-80 degrees Celsius, whereas it used to be consistently 90 degrees).
Do you think it could be related to the injectors (still the original ones on the 1Z)?
I actually suspect the thermostat more. However, I haven't done anything about it yet.
Translated on 22-08-2026, 6:46.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post10-05-2004, 20:18    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
D. wrote:
@ Manuel Thomas
I would have suspected the thermostat more,
but I haven't done anything about it so far.
Fuel injectors icon_evil.gif nenene.
Just install a new thermostat and that should fix it.
@flo__911
I can't make sense of this description.
What exactly was exchanged, and why? icon_eek.gif [/quote]
B.Eng (FH) u. KFZ Meister
Translated on 22-08-2026, 6:47.
D.
Post12-05-2004, 14:20    Subject: TDI VW Golf 3: Smoking Exhaust & Overheating Issues Quote
Sorry!!! - I'm embarrassed now.
Translated on 22-08-2026, 6:49.
No new posts Fuel consumption increases, engine power decreases Diesel Engine Technology
No new posts Climatronic Not Cooling: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Standheizung Qualmt sehr Transmission, Chassis, Body & Interior
No new posts Audi A4 B7: Limp Mode & Smoke - Troubleshooting Diesel Engine Technology
