Crankshaft Rotation: Remove Glow Plugs. | Posts 32+
Go to page: Previous  1, 2, 3
haehnlein
Post06-06-2004, 12:57    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
garth.brooks wrote:
Removing the spark plugs is a job that takes about 5 minutes.
Okay, if that's what you mean... In my case, two spark plug threads were damaged, so the cylinder head had to be removed, sent away (I had to wait for 5 weeks with this awful website www.motorensuche.com), and then reinstalled.
It's absolutely no problem to overtighten the motor with a ratchet icon_wink.gif. You don't need to remove anything for that.
____________
Kein Auto mehr!
Translated on 10-09-2026, 23:49.
SeatArosa1.7SDI
Post06-06-2004, 13:29    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Hi Christian! What caused your threads to break?
Holger.
Translated on 10-09-2026, 23:50.
WarLord
Post06-06-2004, 14:44    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
1Z: Over-tightened threads.
Best regards, WarLord.
Translated on 10-09-2026, 23:51.
haehnlein
Post06-06-2004, 18:42    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Hi Holger,
Aluminum and iron don't get along very well (contact corrosion). The glow plugs are simply corroded and stuck together over time. If you ever try to unscrew a bicycle pedal, you'll see how strongly these two metals can "fuse" together over time.
With spark plug threads, this is obviously problematic because then the cylinder head has to be lowered for the thread insert installation icon_evil.gif.
____________
Kein Auto mehr!
garth.brooks
Post06-06-2004, 21:08    Subject: Glow plugs Quote
Hi Haenlein,
I had replaced all the injectors and glow plugs on my vehicle every 120,000 kilometers (approximately 75,000 miles) due to the PÖL system.
Everything came out cleanly, and then I carefully inserted all the fuses with copper paste – now it works as it should.
Furthermore, it's not aluminum and steel (no iron), but aluminum and nickel - and unfortunately, these two metals don't mix well, which is why metal pastes are used.
If, however, someone were to put cheap oil or even cheap grease into it, then... in this case, it's not VAG's fault.
Translated on 10-09-2026, 23:53.
SeatArosa1.7SDI
Post06-06-2004, 21:53    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Hmm... Copper paste seems to be some kind of miracle product. If you were to grind up copper scraps and cook the shavings with grease... Nah, just kidding. What does that stuff cost?
Holger.
Translated on 10-09-2026, 23:54.
haehnlein
Post06-06-2004, 23:44    Subject: Spark Plugs: Buy, Replace, & Repair Guide Quote
garth.brooks wrote:
(Not iron) but aluminum and nickel - and unfortunately, those don't mix well either, which is why we have metal pastes.
...learned something new again icon_eek.gif. I use "Anti-Seize" as a corrosion protection. This stuff is really great.
____________
Kein Auto mehr!
Translated on 10-09-2026, 23:55.
Gremlin
Post07-06-2004, 6:35    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
I think you misunderstood me. When twisting, an angular offset inevitably occurs between the ES line and the high-pressure connection. This means that the end of the ES line no longer meets the high-pressure connection at a 100% vertical angle. My thought was to determine within what limits the seal can still be guaranteed, or whether the sealing surface is not damaged when tightening at an angle.
Let me put it this way: with the prescribed 25 Nm of torque, it will NEVER seal again...
But otherwise, there have never been any problems. You can carefully bend the pipe a few degrees if necessary, but no more than that.
CU Gremlin.
Translated on 10-09-2026, 23:56.
Post07-06-2004, 7:56    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Yes, I also tightened my connections more than 25 Nm.
"The twisting isn't that bad; usually, you only twist it a little bit. Then the fuel injection lines will just be slightly crooked."
Translated on 10-09-2026, 23:57.
SeatArosa1.7SDI
Post07-06-2004, 15:05    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Hey everyone, do you all have open ring keys as Dremo? What a luxury icon_eek.gif.
Holger.
Translated on 10-09-2026, 23:58.
Gremlin
Post07-06-2004, 15:39    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
either this, or that.
- a good physics teacher.
- 25 years of experience.
CU Gremlin.
SeatArosa1.7SDI
Post07-06-2004, 17:48    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Do you use a spring scale to measure the pull force of the ring pull tab, or do you hang weights on it?
Translated on 10-09-2026, 23:59.
Gremlin
Post07-06-2004, 20:05    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
If it has to be...
'But my mechanic has been dealing with this for over 25 years. And, as mentioned, most connections never really seal or tighten properly, even when tightened to the specified torque.'
It probably works the same way as with Etzold, only if the part is on the assembly line.
The recent events involving oil pan screws and oil filter covers clearly demonstrate this icon_wink.gif.
CU Gremlin.
Post07-06-2004, 22:44    Subject: Crankshaft Rotation: Remove Glow Plugs. Quote
Hey, do you all have open ring keys as Dremo? What a luxury icon_eek.gif.
Holger
No, but 25 Nm is definitely less than what I tightened them to... I just kept tightening them until they were sealed new_all_coholic.gif.
Translated on 11-09-2026, 0:00.
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Empty Weight Confusion: A Fresh Look Diesel Engine Technology
No new posts New small Avatar Upload
No new posts ECU Installation Help: Guide & Tips Diesel Engine Technology
No new posts Porsche Diagnostics: New PoCOM System On-Board Diagnostics (OBD)
