Vibration under the car when accelerating
Johannes
Post21-07-2002, 23:17    Subject: Vibration under the car when accelerating Quote
Hi everyone,
I've recently been experiencing a knocking sound from under the car when I accelerate. It always happens when I brake and then accelerate again. I've already checked the exhaust system, and it seems to be fine.
I don't think the front suspension is the problem either, otherwise I would feel it when steering.
I have an A5 Avant from '98 (AFB). Has anyone experienced this before? If I take it to the mechanic, they will probably disassemble the entire car. :-)Best regards, Johannes
JRoth
Post22-07-2002, 22:30    Subject: Vibration under the car when accelerating Translating...
[Translating...]
hatte letztens auch undefinierbare Geräusche "von unten".
Bei mir hatte sich das Innenleben des Kats gelöst...
war allerdings bei Standgas am lautesten, während der Fahrt weniger im Vordergrund.
nur so'ne Idee!
Gruss, Jürgen
Passat Variant 35i 1Z 05/02 - 01/05
Ford Galaxy AFN 01/05 -07/06
Ford Galaxy 08/06 - 08/09
No new posts Strong vibrations during acceleration General Tips
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts What is the synchronization angle in a TDI engine? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMP ruckelt beim Beschleunigen Diesel Engine Technology
This topic is locked, you cannot edit or reply. Ruck beim Beschleunigen, BLS mit DPF Diesel Engine Technology
No new posts Raddrehzahlsynchrones Klacken beim Beschleunigen... Transmission, Chassis, Body & Interior
No new posts 2.0 TDI BKD extremes Ruckeln beim Beschleunigen Diesel Engine Technology
