Thank you for the answers!
thom wrote: |
Did you perhaps do something to the front of the engine mount, because it needs to be aligned with the...
example: when changing dental files, etc., is that thing located opposite the file? |
Yes, I experienced that during the timing belt replacement. However, I believe I installed it correctly.
Yesterday, I also thoroughly checked the remaining engine mounts from underneath -> they are fine.
Ulf wrote: |
| I can hardly imagine that |
You are destroying my beautiful theories...
But that actually makes perfect sense.
Yesterday, I noticed some engine oil leaking between the engine and the transmission. It could be a crankshaft seal, but it might also be from the recent oil change. I'm going to give the engine a wash.
So, in my opinion, the only things that could be the problem are the clutch and possibly the seal.
