Lader / Notlaufproblem beim AXR PD | Posts 16+
Go to page: Previous  1, 2
Post13-07-2004, 12:36    Subject: Quote
@0815Viewing profile: 0815
The Waste-N75 and the VTG part are quite different from each other.
My EGR valve (N208??) is also quite expensive.
I'm also familiar with the possibility of using the AGR valve as part of a variable turbine geometry (VTG) system, but I've never actually done it.
The VTG TDI I've been working on previously only had one issue with the mass airflow sensor (MAF), which we immediately found using VAGCOM and a test drive icon_smile.gif.
Translated on 14-08-2026, 11:30.
Olaf
Post13-07-2004, 12:45    Subject: Quote
I had the same problem with those intermittent errors (sometimes it would even overspeed under full load). I just kept driving. The loader then lasted another 80,000 kilometers. After replacing [the part], everything was fine again.
Regarding vehicles from the year 2002: In this context, we were only discussing the AMF (1.4 TDI) engine. The turbocharger boost control system is different in that engine compared to yours (because it uses a wastegate turbocharger).
And yes, they are all direct-injection engines. However, to my knowledge, the AMF is the only direct-injection engine with a wastegate turbocharger.
See you then.
Olaf.
P.S.
If they want to charge you 23 euros for the diagnostic scan, it's better to go to an independent garage... they might be cheaper or not charge anything at all.
Translated on 14-08-2026, 11:32.
Back to top Profile PM Email
0815user
Post13-07-2004, 13:41    Subject: Quote
Could a faulty mass airflow sensor (MAF) cause these intermittent issues? In my opinion, if the MAF is malfunctioning, it could produce incorrect readings, leading to either too little or too much fuel being injected.
'@Olaf I've also had at least one instance of overspeeding under full load... so it sounds quite similar to your problem icon_wink.gif'
Translated on 14-08-2026, 11:34.
Post13-07-2004, 14:05    Subject: Quote
0815user wrote:
Could a faulty mass airflow sensor (MAF) cause these intermittent issues...? In my opinion, it would then produce incorrect values, leading to either too little or too much fuel being injected.
Too little is fine; too much isn't possible because that would require ignoring the torque curve (see specialized articles, e.g., on low-speed high-torque tuning).
Translated on 14-08-2026, 11:35.
Olaf
Post13-07-2004, 14:15    Subject: Quote
These overruns occurred in my vehicle when the engine was running very hot (e.g., driving through the Kassel Hills and accelerating from approximately 100 km/h to almost maximum speed on every incline). Overruns were practically never observed at lower engine temperatures.
Unfortunately, it turned out to be the charger... It probably had a defect from the beginning... but without the chip, it wouldn't have shown any problems.
Olaf.
Translated on 14-08-2026, 11:36.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts VNT-15 Lader unterschied beim AFN und ALH Diesel Engine Technology
No new posts Luftablass Pfauchen wie bei einem Wastegate beim VTG Lader ? Diesel Engine Technology
No new posts T4 Lader Diesel Engine Technology
No new posts Lader Nr. vom AMF-Motor Diesel Engine Technology
