Oil Pan: Same for 85kW/96kW Engines?
Thomas K
Post10-08-2004, 8:39    Subject: Oil Pan: Same for 85kW/96kW Engines? Quote
I have always had the oil changes done at the workshop. However, since I was able to get oil at a good price, I wanted to do the oil change myself. When I loosened the screw, I noticed that it was not properly tightened, and some oil was already leaking out.
A colleague has a defective 96kW engine (engine code?) in his garage. Therefore, I could potentially attach the oil pan from that engine to mine. Does anyone know if the oil pans of the different TDI engines are the same?
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Translated on 14-09-2026, 13:53.
Post10-08-2004, 11:59    Subject: Oil Pan: Same for 85kW/96kW Engines? Quote
You can definitely use the oil pan from an ASZ engine (96 kW) on your AJM engine.
Translated on 14-09-2026, 13:54.
Thomas K
Post10-08-2004, 13:12    Subject: Oil Pan: Same for 85kW/96kW Engines? Quote
The tub is sealed to the engine using sealant. What about the sensor next to the oil drain plug? Is that also sealed with silicone? What other parts (seals) do I need to replace?
Gruß Thomas
Translated on 14-09-2026, 13:55.
Post10-08-2004, 14:37    Subject: Oil Pan: Same for 85kW/96kW Engines? Quote
"This is the oil quality sensor. I can't say exactly how it's attached or sealed, but there are people here who have already modified it. Try using the search function; I remember seeing a post about it."
Thomas K
Post10-08-2004, 16:04    Subject: Oil Pan: Same for 85kW/96kW Engines? Quote
I was searching online and found a discussion about a retrofit installation where an oil sensor was to be added. In that discussion, silicone was also mentioned as a sealing agent. Since the pan is sealed in that way, I assume the sensor is also sealed in a similar manner. If anyone has more specific information, I would appreciate hearing from you.
Gruß Thomas
Translated on 14-09-2026, 13:56.
No new posts PD Motor Workshop: 96kW, Servo Return Hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Compressor Replacement: 96kW to 85kW (Sharan) On-Board Diagnostics (OBD)
No new posts Idling speed control 85kW PD /AJM Diesel Engine Technology
No new posts Are the AFN and AHU cable harnesses identical? Diesel Engine Technology
No new posts Injection pump, identical? Diesel Engine Technology
