Taxi Clutch Upgrade & Motor Mount Prices
dr_braun
Post30-08-2004, 16:40    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
Are there any factory-reinforced clutches available for TDI engines that were originally used in taxi versions, or are they all the same?
Which manufacturers / suppliers offer engine mounts for the AFN engine in the Golf 3 / Ibiza? At VW, all three together cost €158.80.
Best regards, Dr. B.
Translated on 11-09-2026, 20:27.
Tobi
Post30-08-2004, 19:32    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
Okay, so a colleague of mine has a Passat 35i used as a taxi, with a 1Z engine. The clutch is the same as the one used in other Passats with a 1Z engine.
Translated on 11-09-2026, 20:28.
Post30-08-2004, 23:18    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
According to the VW website, apparently nothing has changed regarding the engine.
http://www.volkswagen-taxi.de/
matthias
Henrik
Post31-08-2004, 8:18    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
So, according to the VW homepage, apparently nothing is different with the engine...
matthias
Really? Where do you see that?
I only found the following (just rambling, nothing concrete).
'New car warranty.'
All components that are particularly stressed in the daily use of taxis are already standardly reinforced in Volkswagen Taxi models. Should anything ever happen, the full new car warranty applies during the first and second years - of course, without any mileage limitations. http://www.volkswagen-taxi.de/
It would be interesting to know which components are being referred to.
Translated on 11-09-2026, 20:29.
Tobi
Post31-08-2004, 9:16    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
The chassis is partially different.
I can't say for sure at the moment if anything else is different.
Translated on 11-09-2026, 20:30.
Post31-08-2004, 18:22    Subject: Taxi Clutch Upgrade & Motor Mount Prices Quote
So, I've only read about changes to the suspension. If anything had been changed about the engine, the folks at VW would definitely have explicitly pointed that out.
Translated on 11-09-2026, 20:31.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf TDI: Upgrade Clutch for More Power Diesel Engine Technology
No new posts LUK Clutch for ALH engine Diesel Engine Technology
No new posts Clutch 1Z Diesel Engine Technology
No new posts A4 8K SAC Clutch: Replacement & Upgrade Transmission, Chassis, Body & Interior
