Doku Polo 9N, water accumulates in the footwell during heavy rain (Solution)
Michael II
Post05-09-2004, 11:39    Subject: Doku Polo 9N, water accumulates in the footwell during heavy rain Quote
Water accumulates in the footwell during heavy rain.
Cause:
Water is flowing into the holes located in the area of the front wheel arch / hinge of the front hood, towards the A-pillar.
The water accumulates there and then flows through the drain hole located beneath the trim panel into the footwell.
Solution:
Holes in the area of the front wheel arch / Seal the front hood hinge with body sealant. To better access the holes, the hinge must be disassembled.
Tschüss
Michael II
Ratings - Doku Polo 9N, water accumulates in the footwell during heavy rain
No new posts Document: Passat, Model Year 2000, Window Seal is Raised/... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Noises & Sounds - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wasser im Fußraum nach Regenschauer, Passat Var 7/99 Transmission, Chassis, Body & Interior
No new posts Water in the footwell - mold Transmission, Chassis, Body & Interior
No new posts Boost Pressure > 0.5 bar: Only with heavy soot Diesel Engine Technology
No new posts T6 Caravelle: Top-area cooling, bottom-area heating. Transmission, Chassis, Body & Interior
