Document 1J 4Motion, Oil Leak on Haldex Coupling (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post16-09-2004, 9:18    Subject: Document 1J 4Motion, Oil Leak on Haldex Coupling Quote
Oil drain via the Haldex coupling vent.
Cause:
In vehicles of type 1J, under specific conditions, oil from the Haldex coupling's vent line can enter the vehicle's longitudinal support beam.
The oil exits at the point of installation of the breather hose or further forward in the direction of travel, near the bottom of the vehicle.
Solution:
Check the Haldex coupling oil level. The oil level should align with the edge of the oil check bore. This is a prerequisite for the next steps.
If the oil level is low, replace the oil in the Haldex coupling.
After the above-mentioned oil level has been ensured, remove 50 ml of oil from the Haldex coupling via the check hole.
Tschüss
Michael II
Ratings - Document 1J 4Motion, Oil Leak on Haldex Coupling
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku MKB AKF, Ölverlust am Ölstandssensor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Haldex clutch/Haldex axle drive 5. Which generation of oil? Transmission, Chassis, Body & Interior
No new posts Disable 4Motion control module in the CAN gateway On-Board Diagnostics (OBD)
No new posts 4Motion Kraftübertragung ändern Transmission, Chassis, Body & Interior
No new posts BKD Golf 4Motion mit Ladedrucksymptomatik On-Board Diagnostics (OBD)
