Automatic transmission 01M.J - Identification codes and error codes (Solution)
Michael II
Post15-08-2002, 12:56    Subject: Automatic transmission 01M.J - Identification codes and error codes Quote
Automatic transmission 01M.J.
Sure, I'd be happy to translate the text for you. Please provide the text you would like me to translate.
1. License plate.
2. Error codes and their causes.
1. License plate.
Gearbox letter code:
DMP.
Manufactured from 01.97 to 08.98.
Type: Golf 1998 onwards, and Bora 1999 onwards.
Engine: 1.9L diesel, 66 kW.
Torque converter identification letter:
QCDC (Turbine shaft with plain bearing bushing).
QCDD (Turbine shaft without a bearing bushing).
Identifier letter for sliding case:
QFB
Number of internal fins:
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 5
Brake B2: 5
Number of outer fins:
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 5
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
DVK
Manufactured from 05.97 to 08.98.
Engine: 1.9L diesel, 81 kW.
QFB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 6
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 6
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
ECN.
Manufactured from 08.98 to 05.99.
QFB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 5
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 5
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
ECR.
Engine: 1.9L diesel, 81 kW and 85 kW.
QFB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 6
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 6
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
ELT
Manufactured from 05.99 to 12.99.
QLB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 5
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 5
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,1441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
ERX
QLB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 6
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 6
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
EPB
Manufacturing: 12:59 PM to 2:00 AM.
QLB
Clutch K1: 5
Clutch K2: 5
Clutch K3: 6
Brake B1: 5
Brake B2: 5
Clutch K1: 5
Clutch K2: 5
Clutch K3: 5
Brake B1: 5
Brake B2: 6
"Translations:"
1. Gang: 2,714
2. Gang: 1,441
3. Gang: 1,000
4. Gang: 0.742
R. Gang: 2,884
2. Error codes and their possible causes.
00258
Solenoid valve 1 N88.
Short circuit to ground.
Short circuit after positive voltage.
Possible causes:
Power outage or short circuit.
N88 defective.
00260
Solenoid valve 2 N89.
Possible causes:
N89 is defective.
00262
Solenoid valve 3 N90.
Possible causes:
N90 malfunction.
00264
Solenoid valve 4 N91.
Possible causes:
N91 defective.
00266
Solenoid valve 5 N92.
Possible causes:
N92 is defective.
00268
Solenoid valve 6 N93.
Possible causes:
N93 is defective.
00270
Solenoid valve 7 N94.
Possible causes:
N94 defective.
00281
Speed sensor G68 not providing a signal.
Possible causes:
Line interruption.
G68 error.
00293
Multifunction switch F125: Undefined switch state.
Possible causes:
Line interruption.
Multifunction switch F125 is defective.
00297
G38 gear speed sensor.
No signal.
implausible signal
Possible causes:
If the control unit detects an implausible signal,
What are the connector pins for on the sensor, specifically for the transmission speed?
G38 and the speed sensor G68.
swapped
G38 malfunction.
Line interruption.
00300
Sensor for transmission oil temperature, G93.
Possible causes:
Line interruption.
G93 defective.
Sure, here's the translation:
"Note:"
First, check the connectors for contact corrosion or water ingress, and replace them if necessary. When error codes indicate a fault in the connector at the transmission, check the connection between the conductor film/slider box and the cable harness.
00529
Speed information is missing.
Possible causes:
Line interruption.
00532
Supply voltage.
Possible causes:
Supply voltage to valves is too low.
00596
Short circuit between valve lines.
Possible causes:
10x connector for conductor film.
Sliding box and cable harness.
Slider track guide broken.
00641
ATF temperature signal too high.
Possible causes:
The transmission is overheating, reaching a maximum temperature of 148°C. If the ATF level is too high...
-The temperature switch engages the lowest available gear.
Vehicle's load is too high.
ATF level not within acceptable range.
Faulty transmission oil temperature (ATF) sensor.
00652
Pedestrian monitoring: implausible signal.
Possible causes:
Electrical/hydraulic fault.
Clutch or slide box defective.
00660
Kickdown switch, implausible signal.
Possible causes:
Line interruption.
Kickdown switch F8 is defective.
01192
Coupling for bridging mechanical failures in torque converters.
Possible causes:
Slip coupling failure.
Slide valve defective.
01236
Magnet for selector lever lock, N110. Short circuit to ground.
Possible causes:
Line interruption or short circuit to ground.
N110 malfunction.
01312
Data bus drive failure, no communication.
Possible causes:
Engine control unit (ECU) failure.
01316
Brake control unit, no communication.
Possible causes:
ABS control unit defective.
65535
Control unit defective.
Tschüss
Michael II
Ratings - Automatic transmission 01M.J - Identification codes and error codes
No new posts Automatic transmission 01M.C: Identification and error codes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Codes, Badges & Features Explained Technical Data
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can automatic central locking be disabled? Audi A6 4B Electrical Systems, Vehicle Electronics, Multimedia
No new posts SEAT Arosa: Disable Automatic Door Lock On-Board Diagnostics (OBD)
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
