Bremse lässt sich weit reintreten | Posts 32+
Go to page: Previous  1, 2, 3
quadral
Post06-10-2004, 6:16    Subject: Quote
Do you get the pedal pushed all the way to the floor like this?
Yes.
If so, that smells like a leak in the main brake cylinder's seal.
If this doesn't occur when applying high pedal force, that would also be an indication, as the seals would then provide a better seal.
Do I need to try again with different brake pedal pressures?
The brake system of vehicles with ABS should be bled with the engine running; however, I don't think that the symptom you described is related to air.
Is there a guide available for this? Here's my experience with replacing brake cylinders.
'These parts are from older vehicle generations. I would have liked to have done some more research beforehand, and I probably wouldn't interfere as much anymore, telling the mechanic what to do and not do.'
If the pedal doesn't reach the floor, this can be perfectly normal. After all, the vacuum pump for the brake servo continues to operate while you press the pedal, so the brake pressure is gradually increased.
That would indeed be an explanation. However, it seems like the pedal travel would be very high. After all, the brake pads aren't made of rubber, and the brake lines probably won't expand like balloons.
quadral
(Quote edits by ulf)
Oh, someone edited it again.
P.S.: It seems to be related to the brake booster.
With the engine idling, the brake pedal doesn't sink. It's still strange that the power steering can reduce the brake pedal force to zero. It leaves a feeling of unease.
Translated on 04-09-2026, 22:52.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can AFN be blocked? Diesel Engine Technology
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
No new posts A6 4F ignition won't turn on Electrical Systems, Vehicle Electronics, Multimedia
No new posts Transmission Control Unit: Recording Issues On-Board Diagnostics (OBD)
